SIMPLE algorithm and k-eps turbulence model
Old   October 14, 2002, 05:17
Default SIMPLE algorithm and k-eps turbulence model
zqnwpu
I'm using SIMPLE-based control volume method and K-eps model to calculate the flow fields around airfoils,but when I use much more grids or highly stretched grids near the solid surface, the computation diverges,I don't know what caused this. Can anyone help me with that? thanks!
Zhang
Old   October 14, 2002, 06:35
Default a suggestion
Abhi
keep an eye on the n+ value. See whether the code diverges when n+ is < 11.63 in one of the cells? If that is the case, then derive the value of G, epsilon & wall shear stress using linear velocity profile !
Old   October 15, 2002, 02:31
Default Re: a suggestion
Holidays
If y+ is getting small this can get tricky indeed, as you may not be respecting your model's assumptions. In Aero applications Low-Re k-E models are much more adapted as well as Shear Stress Transport k-Omega type models where you integrate to the walls.
Old   October 15, 2002, 21:46
YANG
Dear Abhi
What's the meaning of G in your suggestion?
YANG
Old   October 15, 2002, 21:55
YANG
Hi, Abhi
What's the lower limit of n+ for k-epsilon model near the solid wall?
Thanks YANG
Old   October 16, 2002, 02:46
Holidays
Yang,
You should read CFD textbook materials! Details about most classical models, their applications and restrictions can be found in the books by Versteeg and Malalasekera (1995) or Wilcox (1993) for a more exhaustive approach. These are only suggestions of reading; there exist a lot more. In these anyway you would find explanations on P and G terms (G is the production term due to body force in general) and a lot more...
Old   October 16, 2002, 03:50
YANG
Dear Holidays
Thanks a lot for you patient help.
YANG
Old   October 16, 2002, 06:00
newcomer
"G is the production term due to body force in general" - it originates when you go for Reynold's averaging. Look at the viscous dissipation.
Old   October 16, 2002, 07:02
Holidays
G is of the form Gbuoy (+Grot + Gresist) with Gbuoy which can be written as -Mu_effective/(Rho*Sigma_Rho)*g*GradRho, ie a term that accounts for buoyancy and body force effects...
Old   October 16, 2002, 08:42
Abhi
Was the question first coined by YANG ? Yang , give me some more inputs abt the way ur code is behaving. May be I can suggest something. READ Turbulent Flows by STEFAN POPE if u have not!!!!!!! A very very good book
Old   October 21, 2002, 18:22
Default Re: SIMPLE algorithm and k-eps turbulence model
  #11
ammar
i am using the TEACH-T code which uses the SIMPLE algorithm and K-E model and i want to modify it to solve unsteady problem what type of code ur using and what do u think of TEACH-T and could the modification be easily accomplished
Old   May 28, 2012, 04:08
milad
Milad_123 is on a distinguished road
Would you please send me the TEACH-T code.
Thanks a lot.
my email : ghorbani.mec@gmail.com
Milad_123 is offline   Reply With Quote
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
