November 8, 2005, 12:37 |
Flame thickness
Hi all,
I am wondering how I can calculate the laminar flame thickness of a flame. The equation is as follows: delta= (Heat diffusion coefficient)/ (density*Cp*Laminar burning velocity). Now, how do I get the values of the heat diffusion coefficient and Cp for a given mixture, say methane/air premixed? Any other equations/correlations which can help would also be of use. Any help would be appreciated. |
November 8, 2005, 14:38 |
Re: Flame thickness
You have to use the kinetic theory of complex mixture for that.
However, the formula you give is an order of magnitude. It may be different by a factor of 3 or even 5 (see Zeld'ovitch / Frank-Kamenetskii --ZFK -- theory). Hence, you can consider that premixed CH4 / Air has the same properties than Air, since CH4 is diluted. Any Handbook can give what you want for Air. |
November 8, 2005, 15:45 |
Re: Flame thickness
you can use the properties of air for cp and K however for the density, it is the density of the unburned fuel, this density should be evaluated at the average temperature ( Tb + Tu ) / 2
November 9, 2005, 07:09 |
Re: Flame thickness
Hi Martin,
I thought the density was the density of the unbrnt mixture rather than the unburnt fuel (CH4)? Also, why at the average temperature? Is this related to the idea of using the gradient of the temperature to give the flame thickness? Thanks. John. |
Total Thickness of Inflation Layer | prikeyma | CFX | 5 | August 28, 2020 03:22 |
Modeling the Sandia flame D with EDC | Christoph_84 | FLUENT | 1 | September 18, 2011 20:24 |
why the flame shape is quadrate? | fireman | FLUENT | 0 | February 16, 2011 11:40 |
Enquiry about the flame simulation in rotary kiln | hassanelattar | FLUENT | 0 | March 25, 2009 07:41 |
premixed flame modeling problem | peiyong wang | CFX | 1 | July 18, 2008 12:02 |
