water pump intakes
Old   May 30, 2012, 14:49
Default water pump intakes
vikas
vikas171092 is on a distinguished road
I am working on a CFD (Computational Fluid Dynamics) model of water pump intakes for cooling systems using Ansys 13.0 (Fluent) software.
I have attached the geometry on which I am working and have few doubts
1) 1) Do I need to give thickness to the pipes and other geometries in order to specify inside part as fluid{water} and outside part as wall {Mild steel}
2) 2) What boundary conditions do I need to specify to the top free surface { i.e pressure inlet or symmetry or pressure outlet …}
vikas171092 is offline   Reply With Quote
Old   May 30, 2012, 15:09
Peter Galimutti
p.galimutti is on a distinguished road
you need to extract fluid volume from your geometry. For that you can extract it manually or use 'fill' option in ansys geometry. For example take a case of a pipe of some length 'L' and inner diameter 'di' & outer diameter 'do'. Now extracting fluid means creating a volume of fluid going through that pipe which will be a cylinder of length 'L' and diameter 'di'.
You do not need to worry about solid material. However if you are doing H.T, you can define the thickness of wall in fluent and the thermal b.cs.
The outer surface is usually termed as 'wall', but can be periodic, symmetric depending on how your fluid model is.
Good thing is fluent automatically sets wall boundaries on those that are not defined when meshing.
p.galimutti is offline   Reply With Quote
Old   June 2, 2012, 08:08
Default Rectangular Grid
vikas
Thanks for answering.
How can i make a rectangular gird at inlet and evaluate velocities at gird points location ??
Old   June 2, 2012, 11:48
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Are you asking about the hexa mesh? I have created the series of video tutorials for making mesh in ICEM CFD. Here is the link
YouTube ICEM tutorials
Far is offline   Reply With Quote
Old   June 4, 2012, 13:45
Peter Galimutti
I did not quite understand what you want to do?
You would want to have grid for the whole domain to evaluate velocity.
Don't you have inlet velocity/ pressure/ mass flow ?
For your geometry you can easily get a hexa mesh (rectangular as you say) using workbench. Try using 'mapped meshing' and 'sweep methods' in Ansys Meshing. You may need to go through Ansys meshing tutorials for getting some decent expertise in hexa meshing.
HTH
Old   June 5, 2012, 05:07
vikas
I want to evaluate velocities at various points on a particular face (inlet in my case). I tried point cloud tool but, it didn't worked for me. So i thought of making rectangular gird at inlet.
Old   June 5, 2012, 22:52
Peter Galimutti
Its very simple. Just export the velocity (u,v,& w) data at the 'inlet'. You'll be able to get a .csv file of the velocity values and their physical co-ordinates.
HTH
Old   June 7, 2012, 14:28
vikas
Thanks !! It worked
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Water Pump to 10 year old kid Selina Tracy Main CFD Forum 1 February 11, 2003 22:19
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 09:29
