Non-newtonian fluid results problem.
Like Tree1Likes
  • 1 Post By michujo
Old   June 24, 2012, 22:50
Question Non-newtonian fluid results problem.
fruitkiwi's Avatar
kiwi
fruitkiwi is on a distinguished road
Dear all,
I have done the simulation with a nonnewtonian fluid, whereby the fluid pass through the a chamber(inlet as a velocity profile) and exit at the outlet tube(p=0). my simplified geometry is a rectangle connect to a tube.
I found out that when the velocity gradient from the middle to the outlet increase, there is more wall shear stress on the wall. When the velocity gradient on the wall decrease , my result shows that there is less wall shear stress on the wall.
I always thought that when the velocity gradient on the wall increase, the fluid will be less sticky , and move fluent, then reduce shear stress on the wall. But my results is opposite to my understanding.
is there any mistake on results or my understanding?
fruitkiwi is offline   Reply With Quote
Old   June 25, 2012, 09:45
michujo is on a distinguished road
Hi, the behaviour of non-newtonian fluids is not unique. There are basically two kinds of non-newtonian fluids as far as I know: shear-thinning and shear-thickening.
- Shear-thinning: the shear stress decreases with the shear strain rate, i.e., the fluid becomes less "sticky" when it is subjected to high velocity gradients. An example of that would be ketchup, as soon as you shake the bottle it will flow easily downwards, otherwise it will stay attached to the walls of the bottle.
- Shear-thickening: opposite behaviour, the shear stress increases with the shear strain rate. Think of a mixture of water and corn starch (check it on youtube and you will see many cool videos where you can see that when this fluid is subjected to high velocity gradients, it becomes almost like a solid, otherwise is pretty fluid).
To sum up: you must check which kind of non-newtonian fluid shear stress vs shear strain rate law your CFD cose is using.
Cheers.
michujo is offline   Reply With Quote
Old   June 25, 2012, 11:20
fruitkiwi's Avatar
kiwi
Cheers.
Hi, Michujo,
Thanks for your advice.
so do you think that Carreau model which under velocity 0.0035m/s , will it have shear thickening effect?
Old   June 25, 2012, 15:48
Hi, I must admit that I did not know this model. A quick search shows that:
\mu_{eff} =\mu \cdot \left ( 1+\left( \lambda \cdot \gamma \right)^2\right )^{\frac{n-1}{2}}
The behaviour of your fluid will depend then on the value of the coefficient n:
n>1: Viscosity increases with the shear strain rate (\gamma), shear-thickening fluid.
n=1: Viscosity is independent of shear strain rate, Newtonian fluid.
n<1: Viscosity decreases with shear strain rate. Shear-thinning fluid. Notice that although the viscosity decreases, the shear stress still increases with the shear strain rate, as it is the product of viscosity times the shear strain rate, so it will increase slower than linearly with the shear strain rate.
n<0: Assuming that 1<<(lambda*gamma)^2 and bearing in mind that shear stress=mu*gamma, the shear stress rate will actually decrease with the shear strain rate (i.e. velocity gradient).
Can you check in your code which value of n is set, I think that is the key of the question. I guess that if you are observing and increase of shear stress with the velocity gradients it seems that your fluid is indeed shear-thickening.
Cheers.
fruitkiwi likes this.
Old   June 26, 2012, 09:39
fruitkiwi's Avatar
kiwi
Hi, Michujo,
Thanks for your explanation.
Yup, i understand it, my one n<1. is belong to shear thinning behaviour.
wall slip law for newtonian fluid tsi07 FLUENT 0 April 19, 2012 12:13
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
CFX results export problem ? nasir CFX 2 November 4, 2011 21:10
Different fluid problem prateek jain CFX 1 May 3, 2007 09:11
Symmetric problem - Assymetric results Mark Phoenics 2 July 2, 2001 09:04
