Conjugate heat transfer
Old   July 17, 1999, 18:00
Default Conjugate heat transfer
Lu Zhang
Hi: I try to simulate the heat transfer between solid and liquid (conjugate heat transfer). The only informaton I have right now is the method pointed out by Patankar in his book(calculating the whole region at the same time and using harmonic mean of thermal conductivity at the interface, but how to deal with the density and heat capacity at interface?). Can anyone give me some advice on such problem? Thank you.
Lu Zhang
Old   July 19, 1999, 15:11
Default Re: Conjugate heat transfer
Hongjun Li
You may simulate the liquids and the solids separatly. For the liquids part, you may use any fluids solver (Patankar, for example). In the solids, you only need to solve the simple heat conduction equation (for complex geometries, use gridless boundary element method, fast and easy).At the interface, you should match both heat flux and temperature from both sides.
You may look at my paper AIAA 94-2933 "Numerical prediction of fluid flow and heat transfer in turbine blades with internal cooling", By. H. Li and A. Kassab. 1994.
Old   July 19, 1999, 15:37
Lu Zhang
Hi: Thank you for your help.
Lu
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
