June 16, 2012, 04:18 |
Divergence while using RSM turbulence model
Bharat
Rep Power: 14 |
Hello everyone,
i am running a simulation for different turbulence models for an airfoil. I am facing AMG divergence or sometimes FLOATING ERROR: OVERFLOW when i am shifting to RSM turbulence model. the procedure i am following is achieving convergence in K-epsilon at first place and then shifting to RSM, the following parameters i used in initial(K-epsilon) stage. Solver:- pressure based, Green-gauss node based Viscous:- Standard K-epsilon Boundary conditions(under turbulence):- K and epsilon Scheme:- SIMPLE 1st order for 100 iterations then 2nd order(URF:- momentum reduced to 0.5 from 2nd order) By about 4000 iterations convergence is achieved. NOW, i go back to viscous:- under solver-->viscous:- RSM, linear pressure strain etc and rest kept the same(parameters which i used for k-epsilon). By about 100 iterations AMG divergence occurred P.S:- please correct me if i am doing anything wrong! -do i have to initialize it again? thanks in advance bharat |
July 18, 2012, 18:23 |
Casey
Rep Power: 16 |
You don't have to initialize again, you can use the solution from k-epsilon to converge with RSM.
I wonder if you are running into issues with your boundary conditions. Are you checking your Y+ values at the walls? |
July 19, 2012, 05:16 |
Bharat
Rep Power: 14 |
Hey Casey,
Thanks for your comments. i'll keep that point in mind. and yes i am checking for y+ values. bharat |
July 23, 2012, 05:16 |
Rami Ben-Zvi
Rep Power: 17 |
Smells like a Fluent simulation to me. If so - why don't you post it in the Fluent-dedicated forum?
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
turbulence model equation | Andy Chen | FLOW-3D | 4 | January 1, 2010 21:45 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 13:19 |
