Implementation of Simple Algorithm
Like Tree1Likes
Old   August 11, 2012, 08:52
Default Implementation of Simple Algorithm
JunaidAhmad's Avatar
Junaid Ahmad Khan
JunaidAhmad is on a distinguished road
HI to All,
I am trying to solve Lid Driven Cavity problem using Finite Volume Method, for that i want to use Simple Algorithm. I have all ready solve LDC using Artificial Compressibility now i want to use SIMPLE Algorithm to solve velocity-pressure coupling, for that i am following Versteeg's book.
I am using steady navier stokes equations for LDC.
The procedure that i have adopted is given below:
1. Initialize u*,v*,p*
2. Solve Discretised momentum equation and Calculated u*,v*
NOW comes the problem. in step 3 when i try to calculate p'.
3.
the equation is
a[i,j]p'[i,j]=a[i-1,j]p'[i-1,j]+a[i+1,j]p'[i+1,j]+a[i,j-1]p'[i,j-1]+a[i,j+1]p'[i,j+1]+b'[i,j]
a[i-1,j]=(d A)[i-1,j]
a[i+1,j]=(d A)[i+1,j]
a[i,j-1]=(d A)[i,j-1]
a[i,j+1]=(d A)[i,j+1]
b'[i,j] = (u*A)[i-1,j]-(u*A)[i+1,j]+(v*A)[i,j+1]-(v*A)[i,j-1]
In this equation i need d to be calculated which is d=A/a where a is the centeral coefficient of velocity equation.
where i try to calculate this it some how a become zero which makes d=infinity. and p' become undefined or infinity. that cause problems in step 4 i.e.
4.
p[i,j]=p*[i,j]+p'[i,j]
u[i,j]=u*[i,j]+d[i,j]*(p'[i-1,j]-p'[i,j])
u[i,j]=u[i,j]+u[i,j]*(p'[i,j-1]-p'[i,j])
5. Set Boundary condition for u and v
6. Set Wall presure gradient to zero
7. Copy Values
p*=p
u*=u
v*=v
8. Check Convergence. and goto Step 1
My main problem is step 3 any sugesstions for that? (I am using c++)
Regards
Junaid
JunaidAhmad is offline   Reply With Quote
Old   August 12, 2012, 06:37
leflix is on a distinguished road
Originally Posted by JunaidAhmad View Post
the equation is
Junaid
Hi Junaid
I do not know how you defined your notations but your implementation is a bit weird.
You should rather have something like:
ap[i,j]p'[i,j]=aw[i,j]p'[i-1,j]+ae[i,j]p'[i+1,j]+as[i,j]p'[i,j-1]+an[i,j]p'[i,j+1]+b'[i,j]
leflix is offline   Reply With Quote
Old   August 12, 2012, 12:00
Junaid Ahmad Khan
Yes your are correct yours make more sense. Mine your are same.
So any thoughts how to calculate d
Old   August 12, 2012, 18:36
Michail's Avatar
Michail
Michail is on a distinguished road
Hi Junaid Ahmad!
Take a look here http://www.cfd-online.com/Wiki/Sampl...9_-_Fortran_90
Hope this will help
Michail is offline   Reply With Quote
Old   August 12, 2012, 22:09
Junaid Ahmad Khan
This is Pressure Correction File. First let me tell you that i have no working knowledge of FORTRAN So its hard for me to understand this. If I am not wrong then its your code. it will be very help full if you explain it and tell me which book you follow to develop your understanding. Or at least explain the Highlighted terms in this code.
Regards
Junaid
Subroutine Solve_Pressure_Correction
include 'icomm_1.f90'
DpU(2:NXmax,2:NYmax) = 1./Ap(2:NXmax,2:NYmax,1)
DpV(2:NXmax,2:NYmax) = 1./Ap(2:NXmax,2:NYmax,2)
! vertical faces East - e
Do 101 I=1,NXmax
Do 101 J=1,NYmax-1
If((i.ne.1).and.(i.ne.NXmax))then
DXc_e = Xc(i+1,j+1) - Xc(i,j+1)
S_e = Y(i ,j+1) - Y(i,j )
VOL_e = DXc_e * S_e
APU_e = 0.5 * ( DpU(i,j+1) + DpU(i+1,j+1) )
Ul_e = 0.5 * ( F(i,j+1,1) + F(i+1,j+1,1) )
DPl_e = 0.5 * ( DPx_c(i,j+1) + DPx_c(i+1,j+1) )
DPx_e = ( F(i+1,j+1,4) - F(i,j+1,4) ) / DXc_e
U_e = Ul_e + APU_e * VOL_e * ( DPl_e - DPx_e)
Con_e(i,j) = U_e * S_e
End If
Con_e(1,j) = 0.
Con_e(NXmax,j) = 0.
101 continue
! horisontal faces
Do 102 I=1,NXmax-1
Do 102 J=1,NYmax
If((j.ne.1).and.(j.ne.NYmax))then
DYc_n = Yc(i+1,j+1) - Yc(i+1,j)
S_n = X(i+1,j ) - X(i ,j)
VOL_n = DYc_n * S_n
APV_n = 0.5 * ( DpV(i+1,j) + DpV(i+1,j+1) )
Vl_n = 0.5 * ( F(i+1,j,2) + F(i+1,j+1,2) )
DPl_n = 0.5 * ( DPy_c(i+1,j) + DPy_c(i+1,j+1) )
DPy_n = ( F(i+1,j+1,4) - F(i+1,j,4) ) / DYc_n
V_n = Vl_n + APV_n * VOL_n * ( DPl_n - DPy_n )
Con_n(i,j) = V_n * S_n
End If
Con_n(i,1) = 0.
Con_n(i,NYmax) = 0.
102 continue
Summ = 0.
Do 200 I=2,NXmax
Do 200 J=2,NYmax
S_e = Y(i ,j) - Y(i,j-1)
S_n = X(i ,j) - X(i-1,j)
An(i,j) = 0.5 * ( DpV(i,j) + DpV(i,j+1) ) * S_n * S_n
As(i,j) = 0.5 * ( DpV(i,j) + DpV(i,j-1) ) * S_n * S_n
Ae(i,j) = 0.5 * ( DpU(i,j) + DpU(i+1,j) ) * S_e * S_e
Aw(i,j) = 0.5 * ( DpU(i,j) + DpU(i-1,j) ) * S_e * S_e
Ap(i,j,3) = (An(i,j) + As(i,j) + Ae(i,j) + Aw(i,j))
Sp(i,j,3) = -1. * ( Con_n(i-1,j) - Con_n(i-1,j-1) + Con_e(i,j-1) - Con_e(i-1,j-1) )
Summ = Summ + Sp(i,j,3) !
200 continue
write(*,*)'Sum',summ
write(*,*) Summ
write(*,*)'solve PP'
niter = 0
20 call Convergence_Criteria(3,Res_sum_before)
niter= niter + 1
Call TDMA_1(3)
call Convergence_Criteria(3,Res_sum_After)
If((abs(Res_sum_before-Res_sum_After).Ge.0.0000001).and.(niter.le.500).an d.(abs(Res_sum_After).ge.0.0001))go to 20
write(*,*)'Res_sum_before-Res_sum_After',Res_sum_before-Res_sum_After,niter
! velocities and pressure correction
Do 300 I=2,NXmax
Do 300 J=2,NYmax
DY = Y(i,j)-Y(i,j-1)
DX = X(i,j)-X(i-1,j)
PPe = 0.5 * ( F(i,j,3) + F(i+1,j,3) )
PPw = 0.5 * ( F(i,j,3) + F(i-1,j,3) )
PPn = 0.5 * ( F(i,j,3) + F(i,j+1,3) )
PPs = 0.5 * ( F(i,j,3) + F(i,j-1,3) )
F(i,j,1) = F(i,j,1) + (PPw - PPe) * DpU(i,j) * Dy
F(i,j,2) = F(i,j,2) + (PPs - PPn) * DpV(i,j) * Dx
F(i,j,4) = F(i,j,4) + 0.1 * F(i,j,3)
300 continue
! correct convective fluxes through vertical East faces
Do 701 I=1,NXmax
Do 701 J=1,NYmax-1
Con_e(i,j) = Con_e(i,j) + Ae(i,j+1) * (F(i+1,j+1,3)-F(i,j+1,3) )
end if
if((i.eq.1).or.(i.eq.NXmax))Con_e(i,j)=0.
701 continue
! correct convective fluxes through horisontal North faces
Do 702 I=1,NXmax-1
Do 702 J=1,NYmax
Con_n(i,j) = Con_n(i,j) + An(i+1,j) * (F(i+1,j+1,3)-F(i+1,j,3) )
end if
if((j.eq.1).or.(j.eq.NYmax))Con_n(i,j)=0.
702 continue
Do 501 I=1,NXmaxC
F(i,1,4) = F(i,2,4) !
F(i,NYmaxC,4) = F(i,NYmaxC-1,4)!
501 continue
Do 502 J=1,NYmaxC
F(1,j,4) = F(2,j,4) !
F(NXmaxC,j,4) = F(NXmaxC-1,j,4) !
502 continue
F(:,:,4) = F(:,:,4) - F(3,4,4)
Return
End
Old   August 13, 2012, 04:55
Hi Junaid,
The code of Michail is really well writen and the notations are very understanable because intuitive. Greatings for him !!
You should first read a book on finite volume method and SIMPLE like the ones of Patankar, Peric or Versteek.
The one of Peric should be better because Michail used colocated variables arrangement based on Rhie and Chow interpolation. So for this purpose I think Peric's book is better oriented.
However just reading the code of Michail you understand what he is talking about...
This is 1./AP coefficient involved in the derivation of the pressure equation and correction velocities. Check for simple algorithm in dedicated books.
AP is the central coefficent there is one for U momentum equation --> APU and one for V-momentum APV.
in fact for Michail APU(i,j) = AP(i,j,1)
APV(i,j) = AP(i,j,2)
because he works with vector componnents style
Do 101 I=1,NXmax
Do 101 J=1,NYmax-1
this is the distance between node P and node E
This is the east surface S_e
VOL_e = DXc_e * S_e
this is the iterpolation of 1/APU at east location
this is the interpolation of F on east location.I don't knowyet what is F but it doesn't matter
the same for interpolation of DPx
this is the gradient of variable F at east location usint central difference.
probaby the gradient of pressure I guess
This is the interpolated velocity using at east location using the interpolation of Rhie and Chow
this is the convective flux.
End If
End
Really get a book on FV , SIMPLE algorithm with Rhie and Chow interpolation and everything will be clear for you because the code is really clear!!
Michail likes this.
Old   August 13, 2012, 06:31
Junaid Ahmad Khan
Thanks,
I am following verseek's book, and in it d(i-1,j)=A(i-1,j)/ap(i-1,j)
A(i-1,j) is area of west face
ap(i-1,j) is central coefficient of velocity
the problem is when i calculate ap by use the value of u* and v* and use it to find p' it some how blow up the velocity field, and when i use that to calculate ap which is ap = aw+ae+an+as+dF
For Hybrid scheme in that e.g. ae=Max(De-Fe/2,-Fe,0)
and Fe=0.5*(uP+uE)
De=Gama if dx=dy
so when velocity blowup everything went side ways.
So what should i use when i calculate ap do i use u* or u the corrected velocity.
Anyways i try to find this book of Peric and see how it works.
Old   August 13, 2012, 10:18
Michail's Avatar
Michail
Dear Leflix
May I'll include Your explanations into the code? I guess it'l be better for future?
Regards
Michail
F(:,:,1) - U-velocity
F(:,:,2) - V-velocity
F(:,:,3) - pressure correction
F(:,:,4) - pressure
Old   August 13, 2012, 10:49
Wink
Originally Posted by Michail View Post
Dear Leflix
of course Michail, you are welcome!
Old   August 13, 2012, 18:40
Default SIMPLE FVM solution
Michael Moor
michaelmoor.aero is on a distinguished road
I have a working Poiseulle flow problem based on Versteeg which matches nicely to the Hagen-Poiseulle velocity profile. It is extremey well annotated and culd be of great help.
It has under-relaxation and uses the JAcobi method, and was possible due to members of this forum such as Ztdep and houkensjtu.
The only problems that i have, are that the momentum resuduals do not get much better that 1e-3, and that the largest mesh that i am able to solve for (without divergence or stagnation) is about 34*34.... I would greatly appreciate any help, but for right now, you can look at my code...
Regards,
Michael
michaelmoor.aero is offline   Reply With Quote
Old   August 15, 2012, 11:46
Junaid Ahmad Khan
If you implemented versteeks method then would realy like to take a look at it. you may give me the like of send me the code at tojunaidahmad@hotmail.com
Regards
Junaid
Old   August 15, 2012, 13:11
Michail's Avatar
Michail
Dear Junaid
I offer to take a look through M.Peric codes
ftp://ftp.springer.de/pub/technik/peric/
There are both staggered and collocated grids codes for SIMPLE-algorithm.
As concerned M.Peric book I offer to check torrents and previous posts on CFD-online.
Fight for CFD and CFD will fight for You
Best wishes
Michail
Old   August 16, 2012, 04:39
Junaid Ahmad Khan
Thanks Michail, i need to know what is the best time to add under relaxation factor in the calculation of p, u, and v. now when i revisit the literature i find out that it is the under relaxation factor that cause divergence to me solution.
Regards
Junaid
Old   August 16, 2012, 05:43
Michael Moor
Regards
Junaid
were you using implicit under-relaxation for u and v? what values were you using for under-relaxation to make it diverge? I am having a similar issue...
Old   August 16, 2012, 15:04
Junaid Ahmad Khan
what is the good method for under relaxation do i use
p^{new}= p^{*}+\alpha_{p} p^{'}
u^{new}= \alpha_{u} u+(1-\alpha_{u}) u^{n-1}
v^{new}= \alpha_{v} v+(1-\alpha_{v}) v^{n-1}
or use URF embedded in the discretised momentum equation
Regards
Junaid
Old   August 16, 2012, 15:10
Michael Moor
p^{new}= p+\alpha_{p} p^{n-1}
u^{new}= \alpha_{u} p+(1-\alpha_{u}) u^{n-1}
v^{new}= \alpha_{v} p+(1-\alpha_{v}) v^{n-1}
Regards
Junaid
If you look at Versteeg page 189, you will find that by applying the under-relaxation to the momentum equations yields the under-relaxed form of equations...6.36 and 6.37, they are not separate mehtods, and i believe that it is called implicit under-relaxation, and it the same form as that of peric.
AS for pressure under-relaxation, I understand it such that only the correction is under-relaxed... i.e. pnew = p* +alphap*p'
Old   August 19, 2012, 08:46
Junaid Ahmad Khan
I don't understand i did exactly what is written in book. it didn't work. I did the same think using artificial compressibility and it worked but using SIMPLE method it did not. the only thing left for me is to paste the code a let you guys decide what is wrong with it.
But first i have to go through one more time.
Old   August 19, 2012, 08:50
Michael Moor
It sounds that easy!
Did you get the code that i sent? I have now upgraded it to SIMPLEC also, and it is working well.
Old   August 19, 2012, 12:39
Cool
  #19
Junaid Ahmad Khan
Yes i got the code . and its approach and mine is the same i.e. hi-bride scheme.
why we need SIMPLE Algorithm when We have Artificial compressibility?
Old   August 19, 2012, 12:47
Michael Moor
thank you would be nice.
as for artificial compressibility, that is outside of my knowledge.
Finite Volume -- SIMPLE Algorithm Roger Main CFD Forum 9 September 25, 2023 12:04
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
SIMPLE algorithm confusion lost.identity Main CFD Forum 1 October 7, 2010 11:48
SIMPLE OR SIMPLER algorithm Sergio Costa Main CFD Forum 2 July 29, 2007 06:44
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
