stagnation point at the trailing edge of the airfoil |
August 22, 2012, 03:43 |
mahzad_kh
Rep Power: 15 |
Hi every one
I am modeling an airfoil in an incompressible very low Re flow!In case of a fixed airfoil, for example when I solved the flow for Re500 alfa=10, and plotted the Cp-x diagram, I faced some problem with the pressure coefficient at the TE of the airfoil. It seems that it is fluctuating. I've attached the image here to clear the problem. It is not related to the grid used, because I've tried different grids, and by changing the mesh refinement, the problem didn't solved!For example when I use coarser grid at TE, the fluctuations are less, but on the other hand I cannot capture the wake correctly. And by using the finer grid the fluctuations at the TE are really high. I've validated my results by a cylinder and a duct, and the results were well matched. Has anyone faced such a problem? Does anyone knows how can I deal with such a problem? Is it related to the stagnation point at the trailing edge of the airfoil? Thanks for any word in advance! |
problem in toposet | Ahmed Khattab | OpenFOAM Pre-Processing | 27 | March 3, 2023 21:12 |
ICEM aircraft mesh trailing edge difficulty | MontyR | ANSYS Meshing & Geometry | 4 | July 23, 2011 21:46 |
airfoil trailing edge modelling in gambit | morteza08 | Main CFD Forum | 3 | June 4, 2010 13:36 |
Structured mesh of a 3d sharp trailing edge | Gilles | Main CFD Forum | 2 | May 23, 2008 13:23 |
NO STAGNATION POINT FOR AIRFOIL SIMULATION | Rif | Main CFD Forum | 6 | February 4, 2008 07:33 |
