September 20, 2012, 13:39 |
Variable Viscosity (Numerical Stability)
Rep Power: 14 |
I'm solving some two phase flow problems and have started working on varying the viscosity ratio. I am using a a Crank Nicholson method for the viscous terms. I noticed that for a viscosity ratio of say 0.1 the method become unstable for too large of a time step. If I switch to a backward Euler method the solution behaves nicely for the same time step.
From what I remember the Crank Nicholson method is A-Stable which had something to do with producing decaying oscillations. Does anyone have any references about the Crank Nicholson method becoming unstable for problem with jumps or shocks or discontinuities in coefficients. I know Stefan Turek has done some work with the Fractional-Step theta scheme. Anyone have experience with that? ~Rob |
Can a turbulent flow converge in laminar simulatio | KM | CFX | 7 | December 5, 2019 00:25 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
numerical stability due to cross derivatives | wen long | Main CFD Forum | 2 | September 12, 2005 02:10 |
variable viscosity -NOT! | George Bergantz | Main CFD Forum | 15 | September 19, 2000 14:28 |
Numerical Viscosity? | P. Diao | Main CFD Forum | 9 | August 21, 1998 07:46 |
