airfoil grid generation
Old   January 16, 2006, 04:09
Default airfoil grid generation
Bounecer
Please I'm using structured C-grid generation to simulate numerically flow about NACA airfoil. My code program diverge after it reachs 10**(-4) between two concequative velocity values.
That's some details of my code program: 2D, incomressible, laminar, viscous flow grid dimension:191x145 streching coeffecients: 0.12, 0.12 Re number: 2x10**3 relaxation parameters for all variables: 0.05 finite volumes method with upwind second order scheem SIMPLER Algorithm
Please i'm ready for more details if you would like help me to run my code.
Old   January 16, 2006, 05:15
Default Re: airfoil grid generation
B787
Just try running ur code without the airfoil...just a plane flow..theoretically the solution should not change with time. If u still get an error, i think the probability of finding an error due to the grid (like calculation of angles etc) is more. The other thing i suggest is try a simple test case--a flat plate or flow between parallel plates and see wat happens.
regards,
B787
Old   January 16, 2006, 06:46
Bounecer
Thanks verry much for y're interest, I'm runing the code for permanent case and zero angle of attack. But i have a difficulties in imposing boundary conditions in numerical domain
Old   February 6, 2006, 23:09
santiago suarez
I need only a grid generation soft (free) for simulate a C or O grid about a 2D profile (orthogonal mesh in a computational plane), please if you know some one link send me it.
Thanks
Santiago Argentina
Old   February 6, 2006, 23:42
Ahmed
studentfluent.com, click on mesh lib and download all the mesh files you wish for free
Old   February 7, 2006, 10:27
zonexo
u can try ugrid or shore-cfd. one is o-grid, another is c-grid. google them...
Old   February 10, 2006, 21:04
santiago suarez
thanks Ahmed, IŽll try. Later I`ll talk about.
Bye
Old   February 10, 2006, 21:05
santiago suarez
thanks zonexo, IŽll try. Later I`ll talk about.
Bye
Help! Validity of unstructured grid on S809 airfoil didiean FLUENT 11 April 3, 2011 02:10
2D airfoil simulation, turbulence, boundary layer, unstructured grid louis.langouche@gmail.com FLUENT 0 March 3, 2010 08:19
cartesian grid generation method Abu Taleb Main CFD Forum 7 April 14, 2001 09:49
Cartesian grid generation method Abu Taleb Main CFD Forum 0 April 8, 2001 12:03
Data Structures for unstructured grid generation Dinesh Godavarty Main CFD Forum 0 December 5, 2000 10:49
