October 11, 2012, 14:31 |
Resolved/modelled scales in LES
Sheyda
Rep Power: 13 |
Hi everyone.
Well this is my first post here, hoping to get some insight into LES. We know that in LES the large scales are resolved and the effects of smaller ones (sub-grids) is modeled, right? But, 1- How do you make sure that the appropriate energy-containing scales have actually been resolved? 2- How could you know what scales are present in a flow at all? 3- How you can assess what scales have been resolved in your LES? Thank you!
_ Someday we'll all look back at this and laugh _ |
October 11, 2012, 14:41 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
1- it depends on the extension of the inertial range of the energy spectra, you have to put the filter lenght within the inertial range. In simple words, the filter lenght is related to the computational grid therefore the Nyquist frequency must be greater than the frequencies related to the energy-containing eddies. 2- The estimation is based on the limit provided by the Kolmogorov scale, the smallest one. 3- You should better formulate the question... If I see correctly what you mean, the resolved scales in LES are (formally) all within the filter length. However, the SGS model acts on the resolved scales, mainly those close to the filter lenght |
October 12, 2012, 19:09 |
#3 | ||
Sheyda
Rep Power: 13 |
Thanks, I appreciate your help. Have more questions now:
And, from your LES results how would you evaluate the smallest scales that have actually been resolved?
_ Someday we'll all look back at this and laugh _ Last edited by Ms.Sheyda; October 16, 2012 at 19:04. |
October 13, 2012, 17:36 |
#4 | |
Rep Power: 71 |
I suppose you are quite new in this field... the Kolmogorov scale depends on the physics (energy production, dissipation and viscosity of the fluid) not on the LES results... in LES the Kolmogorov scale is never resolved... what's more, in LES the dissipative region of the energy spectra remains almost always unresolved, apart when you have a very fine grid in regions of the flow of local low Re number (e.g. a resolved boundary layer) |
October 16, 2012, 18:53 |
#5 | |
Sheyda
Rep Power: 13 |
I understand now that kolmogorov scales are smallest scales and could only be resolved in very fine LES. My question is if the Kolmogrov scales are defined by physics of the flow (i.e Re number and energy dissipation), how we can work it out and actually estimate the kolmogrov scales to check how far is our LES resolution from a fully resolved turbulence? We have a equation relating kolmogrov length scale to dissipation rate and Re number. Say in LES of simple channel flow we have Re number but how we work out the energy dissipation from which we could calculate kolmgrov scale?
les scales |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
LES on a scaled geomentry (Mesh and Large scales) | comb | Main CFD Forum | 0 | February 8, 2011 06:21 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
characteristic time and space scales while formulating appropriate LES model | yinjunlian | FLUENT | 0 | April 28, 2009 04:03 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
