March 6, 2006, 00:13 |
k-e boundary conditions
Hi friends
I am working on a FVM code using k-e turbulence model for a simple channel flow I have some confusion over the application of Boundary conditions for k and epsilon and also after first complete iteration for one timestep how to use extract the fluctuating components of the velocities and how to use them for next timestep itertions i am in urgent need please help me friends thank you friends for help bye Ravi Kiran |
March 6, 2006, 06:25 |
Re: k-e boundary conditions
Which aplication u r using, For ur kind I would like to give the following, for k-e model you can give K=(u**2+v**2+w**2)/0.5 as one and you can give L=0.3*H as another boundary condition. These were rough calculations, if u have any experimental values its better.
March 6, 2006, 06:48 |
Thank you shashi
I am trying to simulate Bounday Layer on a pate with k-e model and a channel flow with k-e model so the above two i know how to specify k at wall, just above wall in the FVM code which i am trying to develop and also how to estimate the fluctuating components of velocities from k how to use these fluctuating components for next iterations if u or any one could explain thank you i am in vey urgent need of this data ok bye Ravi Kiran |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
