adaptive meshing on an airfoil
Old   December 18, 2012, 06:28
Default adaptive meshing on an airfoil
Davide Alme
davide.cars is on a distinguished road
Hello to everybody,
i am running simulations on an airfoil, the solution converges (SA turbulence model, first and second order), when examining the yplus values, i find that the trailing and leading edge have regions with yplus>1.
is it good to perform a mesh optimization?if so, where should it be performed?just on the leading, the trailing edge or both?
Is it necessary to have yplus<1 all along the airfoil?
Thank you,
Davide
davide.cars is offline   Reply With Quote
airfoil, mesh, y-plus
adaptive meshing clifford bradford Main CFD Forum 14 September 3, 2022 19:13
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. DarrenC Main CFD Forum 5 July 19, 2010 22:33
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
