No recirculation zone, why??
Like Tree3Likes
Old   February 19, 2013, 02:30
Default No recirculation zone, why??
Osman
o_mars_2010 is on a distinguished road
I have developed a code to simulate a flow past a circular cylinder using Immersed Boundary Method.
I set Re=40, and the free stream inlet velocity to 1 and the diameter of the cylinder 0.1.
The resultant streamlines results have no recirculation zone behind the cylinder .
Could any one help me to know what is the reason?
o_mars_2010 is offline   Reply With Quote
Old   February 19, 2013, 03:42
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
At Re=40 you should have a steady, symmetric separation. Have you reached a full steady state? Are you using upwind discretization? what about your grid?
FMDenaro is offline   Reply With Quote
Old   February 19, 2013, 04:12
Osman
i am using AB-CN discretisation on a staggered grid, the mesh size 0.1D, and a time step of 0.01.
I think i reached the steady state because there is no change in the velocity contours or the vorticity contours is taking place.
Old   February 19, 2013, 04:16
Osman
an intersting thing happened when i changed the Re to 500 i could watch a steady state recirculation zone ????
is my inlet velocity has to be adjusted according to the Re ??
I mean
if Re =40 then the inlet velocity should be
U=viscosity*Re/(D)
because i specified the inlet velocity to be 1, with no relation to Re
Old   February 19, 2013, 06:53
Fix your Re number, then you have to fix two among the parameters U, D, viscosity.
Furthermore, AB-CN is a time integration scheme, but says nothing about the spatial discretization
Old   February 19, 2013, 07:19
Osman
sorry, i used second order centeral difference for the spatial discretization.
I will repeat what you say from my understanding to it:
So, for example if i want to make a simulation at Re= 40 around a cylinder with a diameter 0f 0.1 using the kinematic viscosity of water, then the free stream velocity (inlet velocity) will be equal to: (fixing the diameter and viscosity)
U=40*1.04e-6/0.1=4.16e-4 m/s
and in the case of Re=150, the free stream velocity will be:
U=150*1.04e-6/0.1=1.56e-3 m/s
Old   February 19, 2013, 07:25
correct
be sure you respect the stability constraint for the AB-CN scheme with central second order discretization
Old   February 19, 2013, 07:31
Osman
Thanks a lot for your help.
About the stability condition, i think because i am using an implicit way for the treatment of the viscous term then, the restrict constrain of time will be relaxed, so:
dt<=dx/U
However, i am not sure about the IBM, may be it add additional constrain on the time step!!!
Old   February 20, 2013, 02:19
Osman
I have a very strange results:
When i set the kinematic viscosity as 1.04e-6 i have no recirculation zone.
however, when i set it to 1e-2 i clearly see the recirculation zone.
i calculate the free stream velocity according to the relation i mentioned above in both cases of viscosity.
could you please explain to me why this happened???
Old   February 20, 2013, 05:46
by retaining the same reynolds number?
Old   February 20, 2013, 06:25
Osman
I am using the non-dimensional form of N-S equation, So i have to set the Reynolds no. and the inlet velocity explicitly, the viscosity does not appear explicitely in the momentum equations.
So, lets say i want to make a simulation of flowing water past a circular cylinder with a diameter D=0.1 at Re=40 and the kinematic viscosity of water is 1.04e-6, then the calculated inlet velocity will be U=40*1.04e-6/0.1=4.16e-4 m/s.
I set the parameters like that in my problem, however i didn't have any circulation.
However, when i changed the kinematic viscosity to 1e-2 (i do not know what fluid have such a value) i got circulation zone!!!!!!!!!!!!
So, my question why i do not have a circulation zone for water???
Old   February 20, 2013, 06:29
Osman
Diameter=0.1; % cylinder diameter
%kinematicviscosity=1.04e-6; %water at 20 'C
kinematicviscosity=0.01;
ineltvelocity=Re*kinematicviscosity/Diameter;
Old   February 20, 2013, 08:25
I do not understand what you are done... if you have non-dimensional equations (and a non dimensional domain), the only parameter to set is the Reynolds number!
Old   February 20, 2013, 08:31
Osman
So, how can i specify the inlet velocity (Dirchilit B.C) on a recatangular domain ?
Old   February 20, 2013, 08:36
The non-dimensional inlet is the same as well as the non-dimensional diameter!
Old   February 20, 2013, 08:46
Osman
So, if i have a rectangular domain of 40D * 30D, and a grid size 0.05D
then, the non dimensional diameter will be equal to 1
and the non dimensional inlet velocity will be equal to 1
and the rectangular domain will be equal to 40*30
and the grid size will be equal to 0.05
Old   February 20, 2013, 08:55
Osman
x*=x/D, u*=u/U, t*=t.(U/D)
Old   February 20, 2013, 10:21
.... yes !
o_mars_2010 likes this.
Old   February 20, 2013, 10:23
Osman
Thank's a lot.
Old   March 18, 2013, 22:42
Osman
Dear Dr. Filippo
i have some strange results:
when i set the mesh size to 0.1D, i have a good results for the length of the recirculation zone and the drag coefficient.
l/D=2.33 & Cd=1.55
On the other hand, when i decrease the size of the mesh to 0.05D, which is supposed to give better results, it gives worth results:
l/D=2.03 & Cd=1.39
Could you tell me please what could be the reason ???
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
