suitable Linux core
Old   May 24, 2006, 13:34
Default suitable Linux core
Tam
Dear all
I am bigineer with Linux. if you have experience guide me what version of linux is better (fedora, suse, ...) for sientific work (compatible with related open sources, networking and parallel cmputing and so on).
What is main difference between Unix OS and Linux, what is better?
Kind Regards
Old   May 25, 2006, 12:08
Default Re: suitable Linux core
Márcio
Check the site www.distrowatch.com. It has an updated rank with tens of distribuitions (the versions you refered to), with links to them. The top 2 are ubuntu and suse. I use both of them, and it's hard to say which is better. Online updates are easier with ubuntu, but the Yast tool, provided by suse, makes the administration of your computer much easier.
Old   May 26, 2006, 02:51
Ford Prefect
I use slackware and suse. As previous poster said, the yast tool of suse makes administration quite easy. If you want large control during installation you might want to look at gentoo.
Btw, if you use a commercial cfd software they typically support suse and redhat (not that this matters too much).
Old   May 26, 2006, 07:36
andy
The OS is not particularly important for scientific work except that there is generally more relevant software freely available on Linux and unix.
If you are new to Linux and unsure what is going on then you are probably better off installing one of the main distributions since they have more documentation and better developed administraton and installation software for the uneducated about how Linux works. The Suse distribution is probably the most capable in this respect.
Unix comes in two main flavours: BSD and System V. The former was primarily developed by universities and the latter as a commercial product by AT&T. Most commercial forms of unix are System V based with the notable exception of Apple OSX which is BSD based. The freely available unix operating systems: Darwin, FreeBSD, OpenBSD, NetBSD are evolutions of the academic BSD unix. Linux is something like a copy of System V but it does not really attempt to be the same.
> what is better?
None of them. However, one may be more appropriate to your needs if you define what your needs are.
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
what kind of Linux Fortran is suitable 4 starcd4.0 deisler Siemens 3 March 1, 2007 19:48
Fluent Windows / Linux with AMD X2 dual core Lohen FLUENT 0 July 28, 2006 10:35
