March 29, 2013, 22:46 |
problem in Cf in flow over flat plate
Mehdi Baba Mehdi
hi friends;
I am working on modeling flow with a non-zero pressure gradient (NZPG) over flat plate. Gamma-Retheta and SST K-omega are used as transition and turbulent models. flow with zero-pressure gradient was solved well and its results were accurate according to ERCOFTAC prediction. but in NZPG flow, cf is not consistent with the experimental results. I used TVD (van leer limiter, mid-mod limiter) and QUICK schemes in advection descritization and my grid (as it is shown in picture) has about 53000 cells and first cell near wall is located 1e-6 m from the wall. does anyone know where the problem stems from? if any information is needed in order to clarifying more, please ask to explain more? thanks in advance |
March 30, 2013, 22:58 |
April 2, 2013, 03:26 |
#3 | |
Mehdi Baba Mehdi
thank you so much for your answer. I had read it, but I read it again. unfortunately, it does not anything that can help me to solve the problem. I generated finer grid with about 68000 cells, and change convection scheme, but results did not improve. I think I should find results of numerical modeling by using this transition model (such as intermettency and Retheta contour over NZPG flat plate). do you know where I can find them? I have tried, but I can find anythings. |
April 2, 2013, 11:05 |
Did you implement Gamma-theta model in your own code?
are you solving 2nd order scheme for turbulence quantities as well? What are the inlet turbulence boundary conditions? |
April 2, 2013, 23:36 |
#5 | |
Mehdi Baba Mehdi
the boundary condition I used set based on the date of T3C4 (ERCOFTAC data). other boundary condition are set like in "Correlations for modeling transitional boundary layers under influences of freestream turbulence and pressure gradient". tu. intensity in leading edge calculated based on try and error and the formula Langtry introduced in the end of his thesis. U in far field changes based on change of the cross-sectional area in order to impose pressure gradient (slip wall; wall shear=0). following figure can explain better the geometry and boundary condition. If anything is vague, please ask to explain it. |
April 2, 2013, 23:44 |
Do you have access to some commercial code : Fluent/CFX? Try first there with same mesh and see the results...
I can also try on your mesh in Fluent or CFX if needed... Let me know as now a days I am also going to publish our resutls on LPT turbine transition study under various Reynolds number, turbulence intensities and upstream wakes. |
April 3, 2013, 01:19 |
#7 | |
Mehdi Baba Mehdi
Thank you so much for your kind suggestion. I worked a little with Fluent, but I think I am not experienced enough for applying this problem, so it may take a lot of time to do, although if it is necessary, I will do it. after some investigation on my result, I found out intermittency is not simulated correctly. I had faced this problem when I simulate transition on ZPG flat plate, but with some methods (using under relaxation and source term linearization based on Patankar's suggestion) it was fixed, and results were consistent with benchmark data. |
April 5, 2013, 12:11 |
Detecting transition
Omar Aldabbagh
Dear users,
Your help would be kindly appreciated as I am really stuck on my dissertation. I am struggling to plot the Cf vs Re.x graph and need this to check the location of transition. I am uncertain when it comes to the reynolds number as I have tried using an expression/variable but still could not get the graph. I want to see if there is turbulence and transition on my flat plate but I am not sure if it has been set up correctly. There is a boundary layer on my model but remains uniform across a long distance. All surfaces have been specified as symmetry other than the inlet, outlet and flat plate is obviously a wall. I specified a roughness height hoping that it would show more turbulence/transition but I cannot see anything yet. Thank you for your time to read this Kind regards Omar |
October 31, 2013, 18:50 |
Gecamp
Hey Mehdi(mb.pejvak), have you finally got the skin friction validation for your problem?
I am currently working with the same geometry and I think that your poor validation might be related to the shape of the upper boundary. How did you get that? Have you compared the freestream velocity data with the results of your simulation? |
November 21, 2013, 23:13 |
rajesh
Dear Sir,
I am Rajesh. A from India, I am doing research in the modelling of transitional flows in the RANS framework. I am trying to simulate T3C2 flat plate test case for which i am not finding the geometric details in internet. In ERCOFTAC website also they have provided only the experimental results. If you can please provide me with the geometric details of T3C2 flat plate test case, which will be very use full for my work. |
November 22, 2013, 00:01 |
#11 |
Gecamp
Hey Rajesh, try with equation (23) from the article "Correlations for modeling transitional boundary layers under influences of freestream turbulence and pressure gradient" K.Suluksna, P.Dechaumphai, E. Juntasaro.
They claim that equation (23) should give you the cross section height trend for all cases T3C but the T3C4 (for that you should use equation (22) ). I'm working on T3C4 case and unfortunately that didn't work for me. |
November 22, 2013, 00:10 |
#12 |
rajesh
Thank you so much for the reply..
December 1, 2013, 18:38 |
#13 |
Gecamp
Hey Rajesh, have you finally tried the eq.(23) to shape your domain?
Can you actually get turbulence decay validation as well as the same free stream velocity profile by using the equation suggested in that article? I'm curious about it since that did not work for me. |
December 2, 2013, 00:13 |
#14 |
rajesh
Hi, i tried eq.(23) for the domain to simulate T3C2 test case, the turbulence decay initially didn't match. Then i tried for different viscosity ratios. Finally for viscosity ratio 8 the turbulence decay matched. The free stream velocity profile is matching in favorable pressure gradient region but in adverse pressure gradient its under predicted.
compressible laminar flow over flat plate | varunjain89 | Main CFD Forum | 19 | April 18, 2019 06:07 |
compressible flow over a flat plate | vigii | FLUENT | 2 | January 3, 2012 07:12 |
supersonic flow over flat plate | varunjain89 | Main CFD Forum | 1 | March 23, 2010 08:26 |
tricky flat plate laminar flow | sarat | FLUENT | 4 | September 9, 2005 18:35 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 06:58 |
