April 18, 2013, 06:48 |
torque shatf & power shaft
mauricio
hi!
Im not an air fan expert and i`d like some tips. I have a fan modeled in a closed circuit which is somewhat being constricted past the fan, hence the pressure increaeses a little more. So the pressure difference is higher than the dynamic pressure only. Inlet is atmospheric. A mrf model of my fan alone in a environment, using MRF models, shows a mass flow rate of 12-13 kg/s of air at 2500 rpm. a second modeling, without MRF, but with boundary conditions simulating the flow from the fan (w/o swirling) an average surface pressure of 3400Pa results past the fan! With some simple formulas i have: Code:
shaft power as : massflowrate*deltaP 12.8*3425 = 43520W shaft torque as: shaft power/ 2*pi*N , where N = revolutions per sec 60*43520/2/3.1416/2500 = 166Nm any comments are mostly welcome!
Best Regards /calim "Elune will grant us the strength" |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Torque Converter Pump Torque = Engine Torque? | Torque_Converter | Main CFD Forum | 4 | November 12, 2012 06:44 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
Torque valuation on the shaft of a VAWT | Skywalker | Main CFD Forum | 0 | August 28, 2011 08:32 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 06:19 |
