tornado simulation in CFD
Old   April 20, 2013, 03:31
Default tornado simulation in CFD
Zoheb Nasir
shoumo_30 is on a distinguished road
Hello everyone. I am trying to create a tornado inside a cylinder (2.07 m in height and .4m in radius. The lower part (height = .41m) of the cylinder is the velocity inlet for which I have a UDF function. Rest of the height is sidewall. I have pretty fine mesh near the base and also near the side wall so that I can use enhanced wall treatment. I also adapted the grid in fluent. although I am trying run an unsteady simulation my iteration shows some AMG divergance after sometimes. I am using Reynolds stress model and sidewall is free shear wall. Outlet is normal outflow (top of the cylinder). My mesh size is .025 but near the base and sidewall it is more fine. Thanks in advance for your helps.
Zoheb
shoumo_30 is offline   Reply With Quote
Old   April 20, 2013, 17:07
Default cfd analysis of muffler for calculating bck pressure
mohit
mohit juneja is on a distinguished road
i m working on star ccm can any one tell me pls what are the inital conditions for exhaust muffler like what is the temo. value, inlet velocity, maSS FLOW RATE & WILL I HAVE TO GIVE ALL THESE VALUE OR ONLY ONE ?
mohit juneja is offline   Reply With Quote
Old   April 22, 2013, 04:26
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Which solver do you use?
Also please tell us all discretization schemes.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 7, 2017, 10:24
Ravindra Shende
Ravindra Shende is on a distinguished road
Hi Zoheb,
I am not sure what is causing the divergence but I think the boundary condition at the top of the cylinder might have something to do with it.
At the top boundary you will have both inflow (at the center) and outflow (at the edges) as the tornado is forming in your unsteady simulations. I am not sure how well the normal outflow boundary condition will be able to handle this situation. The total mass inflow through the top surface should match the total mass outflow through the same surface at all time steps.
I hope this gives you something to think about (unless you have already given it a thought, in which case just ignore all this).
Ravindra Shende is offline   Reply With Quote
enhanced wall treatment, tornado, transient analysis
CPU selection (E5-2650) for CFD simulation songxguan Hardware 2 October 23, 2012 16:09
CFD simulation of Progressive cavity Pump MrinalKR Main CFD Forum 2 September 25, 2012 15:29
CFD simulation of Progressive cavity Pump MrinalKR CFX 4 September 13, 2012 07:36
Tornado Simulation ??? Boris Main CFD Forum 2 November 2, 2003 18:10
Solidification CFD simulation Min-Hua Wang FLUENT 0 February 28, 2001 17:40
