latex fonts
Old   June 18, 2006, 02:57
Default latex fonts
taw
Can any one give me a hint where I could get latex math fonts for arial or helvetica. All I could get from ctan site are serif type fonts, or am I missing something. Anyone having experience with this could either send me the .sty file or does it come with a price??. Your input is most appreciated.
taw
Old   June 18, 2006, 10:53
Default Re: latex fonts
Harish
\usepackage{times} gives you times fonts.Also compile your file to pdf using pdflatex rather than ps,fonts would look much better.
-H
Old   June 18, 2006, 21:03
taw
Hi Harish,
Thankyou for the prompt help, but "The most common serif typeface is Times Roman. A common sans serif typeface is Helvetica." You recommended me a serif font, I am after any sans serif, typically ariel or helvetica and particularly for "the math font", for the other text I dont have problem.
The case is the conference paper I am submitting requires the manuscript in words and in ariel, I am already into latex and wants to stick with it. But latex seems to have the texts in sanserief but not for the math, and the paper I prepared now get mixed between theses two opposite fonts and loked really bad, and but I think there is a way out.
Still a suggestion is appreciated.
regards taw
Old   June 18, 2006, 23:51
harish
Every conference has its own latex style file.Check if you could find the one for the current conference.I'm not sure of the commands.If you are using windows you can always change fonts when typing using editors such as texnic center, in linux kile can help you with it.Also lyx the front end to latex has the font selection thing as part of GUI.
Old   June 20, 2006, 02:35
Guillaume
There is a sans-serif font included in the basic latex package. Use the command \textsf{type text here} Hope this helps. Regards
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
LaTeX Rendering Problems on CFD-Wiki pete CFD-Wiki 1 June 12, 2011 08:09
Doxygen Latex prapanj OpenFOAM 0 June 11, 2009 06:40
Latex questiuon (figure) John Dongarra Main CFD Forum 5 August 22, 2007 10:06
what is LaTeX ?? yfyap Main CFD Forum 28 September 6, 2002 12:01
