Jitterin bow shock stand-off distance
Old   June 21, 2006, 07:43
Default Jitterin bow shock stand-off distance
Daniel
Hello
i'm using a 2D Euler shock fitting method to compute the flow around a blunt hypersonic forebody. For some grids, the shock stand-off distance is not monotonically increasing with increasing distance from the stagnation point, but jittering from one node to the next. The solution has convergered! Following data will explain best:
Distance X Y (Flow direction)
form the
surface
0.38387058 0.06252239 -0.99804356
0.37291371 0.15529623 -0.98804356
0.39941824 0.25082344 -0.96804356
0.38611675 0.34648209 -0.93804356
0.41730489 0.43990258 -0.89804356
0.45436577 0.52992732 -0.84804356
0.43276034 0.61562137 -0.78804356
The jittering in stand-off distance disappears with downstream. Anyone any suggestions?
Thanks
Daniel
Capturing bow shock in front of sphere lloco FLUENT 0 August 21, 2011 16:11
real gas shock detachment distance amirmahdi Main CFD Forum 0 May 4, 2010 23:48
Will compression waves overtake a moving shock? GRA Main CFD Forum 2 October 19, 2006 00:24
Shock stand-off distance for blunt body Praveen Main CFD Forum 1 August 13, 2003 22:29
Need the Condition for Particle and Bow Shock Jun Sung Park Main CFD Forum 0 October 13, 2000 04:01
