Unusual turning angle ahead of blade leading edge
Old   May 20, 2013, 19:11
Post Unusual turning angle ahead of blade leading edge
Ryan
carnage2121 is on a distinguished road
Hey,
I running a couple of 2-D simulations on a High Pressure steam turbine airfoils. The issue I am having is that when setting the flow at 0 incidence angle (i.e along the stagnation line that should result in flow impinging the Leading edge), the flow apparently seems to turn way ahead of the leading edge and the stagnation point lies on the suction side away from the leading edge?
To all the turbomachinery experts, is this spurious? I can provide images of my geometry if needed.
My simulations are all done in CFX version 13
Thanks,
Ryan
carnage2121 is offline   Reply With Quote
aerodynamics, airfoils, steam turbine, turbomachinery
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
how to plot attack angle along with impeller span direction at leading edge wildli FLUENT 0 August 31, 2010 14:47
how to change blade leading angle of axial turbine dia aisa CFX 0 June 2, 2008 02:45
