Area consideration in shock tube
Old   May 31, 2013, 05:34
Default Area consideration in shock tube
Subramanyam Natarajan
subramanyamn is on a distinguished road
I'm trying to understand the behaviour of a pressure wave-front as it enters a diverging / converging section in a tube. I tried looking it up in John D. Anderson's 'Modern Compressible Flow with a Historical Approach' text, but it only discusses unsteady waves in uniform closed pipe.
OpenFoam's rhoCentralFoam has a Sod's shock-tube tutorial which deals with uniform cross-section again. I, after reading about behaviour of instruments, know when a pressure wave enters an area of greater cross-section, an expansion wave gets sent in the opposite direction. I am unable to visualize this in a converging-diverging geometry I developed using rhoCentralFoam. I'm unable to understand where I am wrong or how this solver actually considers the area term.
I require help regarding understanding the significance of area in a shock tube. Can someone please help?
subramanyamn is offline   Reply With Quote
Old   May 31, 2013, 09:46
SergeAS's Avatar
Serge A. Suchkov
SergeAS is on a distinguished road
Send a message via Skype™ to SergeAS
Could you attach simple picture of your case ?
OpenHyperFLOW2D Project
SergeAS is offline   Reply With Quote
Old   June 1, 2013, 14:34
Please find the attachments.
A simple introduction:
pipe_caseStraight simulates the evacuation of a high pressure chamber with a pipe connected to atmosphere.
pipe_caseStep simulates the same thing, but the pipe has a larger cross-section step in between.
Theoretically, when the pressure wave-front enters this step, a negative pressure wave should be sent towards the high pressure chamber which should aid evacuation sooner.
Refer: image 2.jpg which shows plots of pressures at a probed location. The sudden drop in pressure due to the step is not seen in the second plot. This is my confusion. Please help!
PS: Request you to run blockMesh, setFields and rhoCentralFoam. I have deleted the timestep data to reduce size.
Old   June 2, 2013, 12:28
SergeAS's Avatar
Serge A. Suchkov
Could you give a picture of the initial pressure distribution and the point where the pressure measurement was performed? Unfortunately I can not read the data in OpenFOAM format.
PS: Build the Mach number distribution behind the shock wave, keep in mind that weak perturbation can not propagate up the supersonic flow
compressible flow, diverging converging, john d andersson, shock-tube
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Modelling Shock Tube with Venting RCBlast Main CFD Forum 1 December 17, 2012 09:40
rhoCentralFoam not reflecting shock in Shock Tube? Astaria OpenFOAM Running, Solving & CFD 5 March 4, 2012 03:07
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
shock tube validation AB Siemens 0 November 21, 2004 18:43
