June 27, 2013, 17:35 |
Question about transitional flow
Meimei Wang
Rep Power: 15 |
Hi
Is the transitional boundary layer thicker than the turbulent boundary layer? Could transitional flow cause instability like strong vortex?
Best regards, Meimei |
June 28, 2013, 04:58 |
Meimei Wang
Rep Power: 15 |
How do you define BL separation? If the BL is separated from the wall due to the discontinuity of the wall geometry, would you also call it 'BL separation'?
June 28, 2013, 05:04 |
venki
Rep Power: 14 |
If the BL is separated from the wall due to the discontinuity of the wall geometry, I think this statement is wrong, Flow Separation depends on fluid property, Geomety, surface roughness
June 28, 2013, 05:06 |
venki
Rep Power: 14 |
Refer Boundary layer theory by schlichting
June 28, 2013, 05:21 |
Meimei Wang
Rep Power: 15 |
I meant: like there is a 90 degree corner, then due to this discontinuity of the geometry, the BL fly away. Could we also call this as BL separation?
June 28, 2013, 05:29 |
venki
Rep Power: 14 |
both are different dont confuse wall separation and flow separation
June 28, 2013, 05:31 |
venki
Rep Power: 14 |
Use LES model to capture exact flow separation
Simple question about pipe flow | husker | Main CFD Forum | 1 | February 29, 2012 03:40 |
Yes-No question about poiseuille flow | amin144 | OpenFOAM | 8 | January 10, 2012 06:10 |
VERY SIMPLE question from people works on unsteady flow | amin144 | Main CFD Forum | 9 | December 9, 2011 04:18 |
Question about Couette Flow | Tiger | Main CFD Forum | 1 | March 23, 2006 23:16 |
transitional cavity flow | elif | FLUENT | 0 | August 12, 2002 04:50 |
