I've just started using MISES for the analysis of the flow through a turbine cascade. Could anyone of you explain the meaning of the following error message,
"Array overflow. Increase IQX", that I get during the grid initialization for the 'panel solution'? Thank you in advance Marco |
more precisely, the error message is
"STOP WAKSET: Array overflow. Increase IQX" Marco |
IQX mast be a paramiter (if misses is in fortran)just increase it ! (your grid is larger than your arrey)
p.s. i thing !! i hope i did't confuse you.. |
Rep Power: 0 ![]() |
Has this been figured out? I get the following message:
>> Reading in coordinate file for: Vane 1 Coordinates read from file blade.v1 Blade 1: 178 points. Sharp leading edge. File read error: stream.v1 Default 2-D X,R,B used. File read error: loss.v1 Zero prescribed pressure loss assumed. Calculating unit vorticity distributions ... File read error: gridpar.v1 Default grid parameters used. Generating panel solution ... Sinl = 0.000 Sout = -0.528 Cy = 0.1112 Cx = 0.0302 Setting wake for blade 1 Setting inlet streamline for blade 1 INLSET: Array overflow. Increase IQX. << PLEASE NOTE: MISES is sold under a commercial license. I do not have access to the source code so I can't change any parameters (i.e. IQX) in the code. My only handle are control files - but I can't find IQX anywhere ... |
Matthias
Rep Power: 14 ![]() |
HI Reichstein,
check your blade.xxx file for identically blade pairs, like: 1.21 0.95 1.13 0.87 0.9 0.71 0.9 0.71 ... ... MISES can not handle this. Greets |
MISES code for analysis of cascade flows | Quamber H. Nagpurwala | Main CFD Forum | 16 | January 7, 2022 04:51 |
MISES, radial turbomachinery | arapha | Main CFD Forum | 0 | September 8, 2011 09:13 |
stress analysis -Von Mises Theory | watashiwa | OpenFOAM | 7 | October 15, 2010 15:43 |
MISES error | abhishek | Main CFD Forum | 3 | October 26, 2007 02:26 |
mises transform | rameez | Main CFD Forum | 1 | January 18, 2000 14:26 |
