Euler ~Navier Stokes equation
Old   September 8, 2006, 23:09
Default Euler ~Navier Stokes equation
Khan
I am new to CFD and learning basics, I have to work on numerical solution of Navier Stokes equation. I just want to know That....... what is main difficulity ..... while solving euler equation. Basically i am working on a problem in which i am facing difficiculties because of Viscous term.
Thanks
Khan
Old   September 9, 2006, 03:26
Default Re: Euler ~Navier Stokes equation
SAEED MAHLOO
HEllo I am saeed mahloo, Aerospace engineer ,student of Iran-MALEK ASHTAR ut. Your difficulty in non-linearity of equation . you can linearize , nonlinear term by linearization: for example x^2 is (x1)*(x) and you should substitue x1 with before iteration. you should guess a value for X1 for example x1=1 and then (1)*(x)=2 then solve this rescent equation. x=1/2 then assump x1=(1/2) then (1/2)*(x)=2..... and you continue..... until x1-x<<<<1 the second difficulty is non defined pressure distribution.... I suggest you study these book : 1- " numerical heat transfer and fluid flow" by suhaz.z.patankar 2- "an introduction to computational fluid dynamics" by versteeg & malalasekera : this book is downlodable in internet but only section to section..... If you need more help Email me.... If you can help me and you have any momentum(EULER) code in 2D I need it ,please read my enquiry in "2D Momentum ,invicid,incompressible,Finite volume" forum, if you can help me please contact me , I work on solving momentum equation on 2D,invicid,incompressible,finite volume . WITH BEST REGARDS
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
coupling KE equation with navier stokes equation prashant FLUENT 0 March 7, 2008 07:05
Newbie:Viscoelasticity and Navier stokes equation Rajil Saraswat Main CFD Forum 2 June 9, 2003 07:21
1-d navier stokes equation Robert Main CFD Forum 0 December 20, 2002 02:14
