October 10, 2013, 09:59 |
nagative volume
shahrbanoo
Rep Power: 13 |
Hi dears...
What does it mean when we have negative volume in mesh? how it happens? thanx... |
October 11, 2013, 04:33 |
hi Dear
saeed
Rep Power: 13 |
maybe it happen when your mesh's are complicated in together and have overlap volume........
October 11, 2013, 12:03 |
Ashwani
Rep Power: 12 |
Negative volumes are normally reported when your geometry contains very small "loops"(the first cell of the boundary layer extends beyond the edge of your geometry)near the curved edges. You can check the following link.
http://www.cfd-online.com/Forums/flu...lume-mesh.html |
October 22, 2013, 17:22 |
SsS
Rep Power: 12 |
Negative volumes occurs in the mesh because of the improper aspect ratio of the elements. It becomes a serious issue once if you try to deform the mesh. You can eliminate these negative volumes by using grid utility application that comes with your gird generator package.
October 28, 2013, 02:45 |
Rami Ben-Zvi
Rep Power: 17 |
You may also get negative volumes also if you have left-handed cells. E.g., in a 2D unstructured grid, when the mesher expect cell nodes indices numbered i-j-k-l in a counterclockwise direction, and you input some cells in clockwise direction.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
