Quality assessment of LES by the subgrid viscosity ratio |
August 19, 2013, 00:03 |
Shuangqing Xu
Rep Power: 12 |
Hi, everybody,
Can anyone help me with the LES quality assessment by means of the subgrid viscosity ratio? I mean, is there any particular requirement about the subgrid viscosity ratio when using LES? I found little relevant information in this forum (http://www.cfd-online.com/Forums/cfx...ratio-les.html) but was still confused. |
August 19, 2013, 03:06 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Furthermore, LES can be performed with many other SGS models other than an eddy viscosity model. |
August 19, 2013, 04:30 |
#3 | |
Shuangqing Xu
Rep Power: 12 |
I'm sorry for not telling the context. I've done a LES with the standard Smagorinsky-Lilly SGS model and was asked for the quality assessment for that. The viscosity ratio method is suggested as one of the standard methods (other methods including the fraction of resolved TKE, a two-point correlation). In the "fraction of resolved TKE" method, it's reported that a good LES should resolve at least 80% of the TKE. So I wonder if there is any similar criterion for the "viscosity ratio" method. Hope this makes the question more clear. Thank you. Shuangqingx |
August 19, 2013, 04:38 |
#4 | |
Rep Power: 71 |
August 19, 2013, 05:57 |
Alex
Rep Power: 47 |
If you are absolutely determined to use the SGS viscosity for the Quality assessment of a LES, here it is:
The definition can be found here for example: Klein, Meyers and Geurts. Assessment of les quality measures using the error landscape approach. In: Meyers - Quality and Reliability of Large Eddy Simulations, pages 131-142. Springer Science+Business Media B.V., 2008 Having applied this to some LES, I can copy what FMDenaro said. It is useless to assess the quality of a LES so use the methods he mentioned instead. One reason might be that the coefficients in the formula are calibrated for isotropic turbulence. |
August 19, 2013, 06:20 |
Rep Power: 71 |
Yes, I partecipated at that conference, the full study was published here: http://people.mech.kuleuven.be/~jmey..._22_125106.pdf However, I did not suggested it as I was quite critical in using this methodology for many reasons... |
August 19, 2013, 19:59 |
Shuangqing Xu
Rep Power: 12 |
August 19, 2013, 20:32 |
#8 | |
Shuangqing Xu
Rep Power: 12 |
One more question, senior. Hartmann et al (Chemical Engineering Science, 2004, 59, 2419-2432. see http://www.sciencedirect.com/science...09250904001575) have some discussions about the eddy viscosity ratio and the grid resolution of their LES (specifically in Section 5.1, the lower right quarter of page 2423). What would you comment on that? Thanks. Shuangqingx Last edited by shuangqingx; August 19, 2013 at 20:33. Reason: wrong use of @ |
August 20, 2013, 03:59 |
#9 | |
Rep Power: 71 |
In any case, I do not agree that the capturing of the Kolmogorov scale by an LES can be assessed by the profiles of SGS viscosity. |
August 20, 2013, 20:05 |
#10 | |
Shuangqing Xu
Rep Power: 12 |
August 21, 2013, 04:48 |
#11 |
Rep Power: 71 |
good
I have some papers published wherein the SGS viscosity profiles were analyzed but I used the dynamic Smagorinsky and the analysis does not imply the LES assessment in terms of capturing of the Kolmogorov scale. |
August 21, 2013, 06:07 |
#12 |
Shuangqing Xu
Rep Power: 12 |
Would you mind showing me some information about the publications to this point?
August 21, 2013, 07:33 |
#13 |
Rep Power: 71 |
see for example
http://link.springer.com/article/10.1007%2Fs00162-010-0202-x#page-1 http://www.sciencedirect.com/science...45793012004537 |
August 21, 2013, 19:53 |
#14 | |
Shuangqing Xu
Rep Power: 12 |
les, quality assessment, subgrid viscosity ratio |
"turbulent viscosity limited to viscosity ratio" | olivier | FLUENT | 11 | October 10, 2015 05:49 |
Different horizontal and vertical subgrid scale viscosities in LES | pablo | FLUENT | 0 | November 13, 2012 15:26 |
turbulent viscosity limited to viscosity ratio | Alex_B | FLUENT | 16 | September 12, 2012 13:17 |
Turbulent viscosity Limited to viscosity ratio | Adrian | FLUENT | 12 | September 21, 2011 04:22 |
subgrid turbulent viscosity for UDF in LES | David TAIEB | FLUENT | 0 | April 2, 2007 08:27 |
