Boundary Layer Equations
Old   November 2, 2006, 13:37
Default Boundary Layer Equations
ROUND
Hello! Does anyone has idea on solving unsteady boundary layer equations. I have two methods on hand: Fully implicit method and Box method. Which one is better to solve a 2-D compressible unsteady boundary layer equation? Thanks for your advice.
Old   November 3, 2006, 06:28
Default Re: Boundary Layer Equations
Tom
I'd use the Keller Box method - it's implicit + 2nd order accurate in space and time.
Old   November 3, 2006, 15:02
ROUND
Thank you, Tom.
I have some more questions.
1.Will box method become tedious when governing equations reach four or five ( there might has 7 by 7 matrix inversion and linearization become tedious )?
2. Is variable transformation necessary for compressible flow?
3. How you advice to do the matrix inversion(implicitly? )?
My email is: JakyL6@hotmail.com. I would appreciate any advice.
Old   November 6, 2006, 03:36
Tom
1. It's only redious if you try to do it by hand.
2. It depends on your problem. Most boundary layer calculations are initiated from a similarity solution which can involve a change of transverse coordinate. If a vertical cordinate transformation is required at the initial station then it's a good idea to solve the equations everywhere in this new coordinate.
3. The way I would perform the inversion is through a block LU factorization. Assuming you've rearanged the equations (as you're Q1 suggests you have) so that the only nonzero entries lie on in a band around the diagonal then you can rewrite your matrix as a triagonal system whose entries are 3x3 matrices. The LU factorization will also be of this form and so it is relatively easy to invert; i.e. follow the methodology for a tridiagonal system with the scalars replaced by 3x3 matrices.
Alternatively you could use a general matrix solver such as BiCG - Although it will be a lot slower.
Old   November 6, 2006, 11:34
ROUND
Tom, Thanks a lot.
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
Combining BCs: wall - outlet. Boundary layer disappears MartinaF OpenFOAM Running, Solving & CFD 1 July 20, 2009 18:14
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 15:39
