2D mesh generation!! HELP...!
Old   October 23, 2006, 03:21
Default 2D mesh generation!! HELP...!
Jesper Sørensen
Hey
I am a construction-engineer student from Denmark, and I have a qustion regarding:
"How to make a 2D-simulation of windflow around i.e an airfoile profile??" The problem is how to generate a 2D-mesh.
This problem i solved in: Ansys CFX release 10 tutorials (Fluid Structure Interaction and Mesh deformation) about a Valve - it is the generation of such a mesh i would like to do!
The way too proceed it NOT by using 3D whit changede Boundery Con. while the length-scale in the 3D-mesh gives problems!!
If anyone can help me/tell me (step-by-step??) how to solve this problem i would be very thankfull!!
Thanks in advance!!
\\Jesper
Old   October 24, 2006, 17:58
Default Re: 2D mesh generation!! HELP...!
M. Lemieux
CFX question? Wrong forum. But CFX cannot accept 2D meshes, it is only a 3D solver. So in CFX, you need to make your mesh one element thick. You can make a 2D mesh in Gambit or ICEM if you are running the case in FLUENT.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 15:08
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
