Backward FAcing Step - Frequency
Old   October 20, 2006, 16:20
Default Backward FAcing Step - Frequency
CFDtoy
I am looking at a BFS problem and would like to know if any measurement of the frequency of the backward facing step chamber has been carried out. (Backward facing step system has its own resonant frequency ..the frequency of the chamber itself..)
Could anyone direct me to papers or comment about it?
CFDtoy
Old   October 21, 2006, 00:23
Default Re: Backward FAcing Step - Frequency
diaw
diaw writes:
Could you please clarify this statement a little more? I simulate & research related phenomena & would be interested in the basis for your statement.
desA
Old   October 22, 2006, 12:19
CFDtoy
Based on the step height to the length of the chamber it can act on its own as a resonant chamber sort of. I was wondering if anyone has tried to measure the frequency of such backward facing step chambers??
CFDtoy
Old   October 23, 2006, 07:55
Jonas Holdeman
Please explain what you mean by "chamber" in the BFS problem. In the standard problem, the downstream duct is uniform and its length is infinite, but truncated for numerical computations with downstream/exit boundary conditions that simulate the infinite length.
In a device like a whistle or organ pipe there is a definable chamber and an inlet/outlet, but a strong interaction between inlet and outlet flow. But that is not the case with the BFS problem.
Old   October 23, 2006, 12:08
CFDtoy
Hi Jonas: I guess I ll rephrase the problem. You are right, the backward facing step problem has inf length downstream.
= <--BFS problem----> ================= = =
= Step length defined=
= Step height defined=
If in the case that the downstream exit is confined and the BFS is made to look like a cavity ...what about the frequency of such chambers?
I am sure there is a finite frequency exist for the chamber...based on the step height and length of the duct there...
Can you suggest or comment about finding the resonant frequency of such chamberS?
CFDtoy
Old   October 23, 2006, 15:46
ag
There is quite a bit of work that has been done on cavity acoustics - the classic paper describing a reasonably good empirically based frequency estimate is the one by Rossiter. Do a google search on "Rossiter equation" and you should find quite a bit. A backward facing step on the other hand has no resonant frequency (that I'm aware of) because only one frequency source is present (the shear layer) and there is no real feedback path.
Old   October 27, 2006, 10:21
Default Re: Backward Facing Step - Frequency
Andrew
There are in fact two very distinct feedback mechanisms in the mixing layer flow. The first is from acoustic disturbances, with the second produced by fluctuations that are induced by concentrations of vorticity present within the layer itself.
Old   October 28, 2006, 21:31
CFDtoy
ag ! That was a great reply ..i found the rossiter eqn and several interesting dynamics and models> Curretly goin thru them..
In the same spirit, can u comment on oscillatory flow into small fluidic channels with these cavity in them ..have u come across any papers onthat ?
Thanks a bunch !
CFDtoy
Old   October 29, 2006, 20:51
ag
I haven't done any work in the area of smal fluidic channels. My work has been focused in the area of aircraft bays.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 11:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
