Verfication problem in cd/cl - advice required |
November 2, 2006, 21:00 |
hello,
i'm trying to simulate 2d pitching/heaving airfoil. I've verified my code with oscillating cylinder and it works. next i tried to verify my code against some published results on pitching/heaving airfoil. the problem is that although the cl compares relatively well, the cd does not. some are close but others are quite far off by 50-100%. i wonder what could be the problem. i've tried to reduce the time step as well as refine my grid but the result does not change much. at this moment, i wonder how i should proceed. can anyone give me some advice? thank you. |
Buoyancy/convection problem - advice sought | njc | Main CFD Forum | 4 | April 24, 2009 11:50 |
Fluent VOF Method - At a total loss advice required please | LSF | Main CFD Forum | 5 | April 13, 2009 21:56 |
Need advice for intercooler problem | joon | Siemens | 5 | September 14, 2003 00:06 |
Advice for convergence problem | David | CFX | 4 | November 3, 2002 03:00 |
CF4 - need advice on setting up multiphase problem | Brett Towler | CFX | 2 | August 18, 2000 16:38 |
