An Open Source mesh generator for Open Foam
Old   March 16, 2008, 14:40
Default An Open Source mesh generator for Open Foam
Ahmed
Has any one on this forum downloaded and successfully installed and run the programme Discretizer http://www.discretizer.org/on a windows system, It looks a bit complicated to have to install all other RUBY programmes before being able to run the proper programme. I would like to know his opinion on the subject. Thank you for your comments
Old   March 18, 2008, 01:44
Default Re: An Open Source mesh generator for Open Foam
Björn Bergqvist
Hello, it is like installing java to run a java program, or install .NET in order to run applications using .NET libraries.
To run discretizer you have to install Ruby + FXRuby. In the future there might be a "one click installer" for discretizer including FXRuby.
If you think it is a bit complicated I wonder if you have installed OpenFOAM on Windows? I thought that was a bit complicated.
Regards Björn Bergqvist http://www.discretizer.org
Old   March 18, 2008, 12:39
Victor Prosolin
Actually, I installed it on Windows with no problems. But on linux (specifically OpenSuse 10.3) I couldn't get it to work. It says "Sorry, this example depends on the OpenGL extension". Also, in the script I had to change "#!/usr/bin/env ruby1.8" to "#!/usr/bin/env ruby" to get even that far.
Victor.
Old   March 18, 2008, 16:23
Björn Bergqvist
Maybe you should install ruby-opengl (rbogl). http://www2.giganet.net/~yoshi/rbogl-0.32g.tar.gz
Did you install ruby-FXRuby from opensuse repositories?
http://packages.opensuse-community.o...rchTerm=fxruby
Regards, Björn Bergqvist http://www.discretizer.org
Old   March 18, 2008, 17:10
Victor Prosolin
Yes, I did install those libraries. I installed fox related stuff from suse repos and ruby-opengl using "gem install ruby-opengl".
Victor.
Old   March 18, 2008, 22:08
Ahmed
I have installed the following 1- TortoiseSVN-1.4.7.11792-win32-svn-1.4.6 2- ruby186-26 3- FXRuby-1.613-ruby186 I still have the same problem, i.e., when I click on discretizer.rb a window opens and closes in less than a second. Cygwin is already installed. I went through the Readme file that comes with the Ruby installation and because they use the MicroSoft Visual C to compile the Ruby interpreter they say some I/O functions may not work. Any clues. Your comments are highly appreciated
Old   March 19, 2008, 01:26
Björn Bergqvist
Did you install FXRuby in the same directory as ruby?
You can open a dos command prompt and execute ruby from that to see what happends.
cd *to where you have discretizer.rb*
ruby discretizer.rb or
c:\ruby\bin\ruby discretizer.rb if it's not in your path
Old   March 19, 2008, 15:26
Björn Bergqvist
Hello, I have not installed from gem, only from tar-files. Maybe it will work if you put require 'rubygems' in the discretizer.rb file.
Björn Bergqvist - creator of discretizer - http://www.discretizer.org
Old   March 19, 2008, 15:36
Victor Prosolin
Yes, that did the trick. Thanks Björn.
Victor.
Old   March 20, 2008, 13:40
Ahmed
Yes, Ruby installes in c:ruby and FXRuby installes in c:ruby\ruby, these are the default values and I have not changed them. Any way, I guess I will have to wait till you come up with the Beta version, sorry to cause you such distractions, you see, OpenFoam is an excellent programme but it lacks the preprocessor which you are developing, I must express my appreciation and encouragment to what you are doing. Cheers and keep up with the good work. I will keep an eye on your web site
Old   September 8, 2010, 10:03
  #11
Wai Sam Wong
anthropoy is on a distinguished road
Hi, although this one seems to be an old post. I have been having the same problem as Ahmed there. I've installed Ruby and FXRuby. Ruby.exe seems to be in the PATH since I was able to execute it directly in the command prompt. I have tried "ruby discretizer.rb" and "discretizer.rb" without success. Any suggestions? Thanks!!
anthropoy is offline   Reply With Quote
Old   September 22, 2010, 03:49
Default Discretizer on Windows
  #12
Björn Bergqvist
bjornthe is on a distinguished road
I've made some changes in Discretizer in order to make it compatible with Windows. Changes will be committed later this week.
Regards
Björn Bergqvist
________________________________________
Björn Bergqvist,
creator of Discretizer,
a free mesh generator for OpenFOAM
_________http://www.discretizer.org_____________
bjornthe is offline   Reply With Quote
Old   September 22, 2010, 07:25
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Thanks Björn!
This is great news! Please let us know when it is done.
Pei
Regards
Björn Bergqvist
phsieh2005 is offline   Reply With Quote
Old   September 23, 2010, 03:55
Björn Bergqvist
Revision 117 at sourceforge should work on Windows. I've only made changes to Discretizer-Setup in that commit.
Björn
Björn Bergqvist,
Old   September 23, 2010, 13:54
Björn Bergqvist
Now I've made a binary release for Windows.
Have a look: http://www.discretizer.org
Björn
Björn Bergqvist,
Old   September 23, 2010, 18:39
Pei-Ying Hsieh
Hi, Björn,
I prefer to run OpenFOAM on OpenSuSE. But, I really would like to use discretizer on MS Windows. Is it possible to setup the case in Discretizer, then, copy the case to OpenSuSE, then, run the case?
PHsieh
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
