November 12, 2013, 11:37 |
1 dimensional heat conduction
Ashutosh
Rep Power: 12 |
We have one dimensional steady heat conduction with heat generation term. I use this to find temperature distribution within a rod. Now, i will require two boundary conditions in space co-ordinates. I specify, one end as insulated and other end with a specified heat flux. Physically this is not correct. However, mathematically the differential equation requires two boundary conditions. So, can we conclude that, we cannot specify two Neumann boundary conditions in this case?
November 13, 2013, 03:30 |
Rami Ben-Zvi
Rep Power: 17 |
Hi dreamz,
Let us try to naively solve your energy eqaution q,x = -(kT,x),x = S assuming for simplicity k and S are constant. integration: q = -kT,x = Sx + A -kT = 0.5*S*x^2 + Ax + B To determine the integration constants A and B, use your BCs: q(0) = 0 => A=0 q(L) = Q = SL (where Q is the prescribed value at x=L). Now you have two problems: (1) A contradiction: if both S and Q are given, you cannot satisfy the last equation. (2) You cannot determine B. Conclusion: the problem is ill-posed. On the other hand, if your BCs were both Dirichlet or one Dirichlet and one Neumann, then the problem is well-posed, as you may see. |
1 dimensional, differential equation, heat conduction, neumann bcs |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
one dimensional unsteady heat conduction | vijeshjoshi23 | Main CFD Forum | 1 | July 10, 2009 21:22 |
Heat conduction through solid rib in periodic duct | Dieter Fauconnier | FLUENT | 0 | October 7, 2004 08:22 |
