Ansys Static Structural
Old   January 15, 2014, 19:58
Default Ansys Static Structural
Arief
Zero is on a distinguished road
Dear All,
What all you know the function command "fixed support & frictional support" to analysis system ?
And I have a model, I give force 6 Tonnage in surface color red.
So do you think, where I should give the command "fixed support & frictional support" in which the parts on this model ?
Bottom view & Side view
If all you know the answer, please for an explanation... Thank's
Zero is offline   Reply With Quote
[ANSYS Meshing] importing a cfd in ansys static structural nauman55 ANSYS Meshing & Geometry 0 July 23, 2013 08:22
Runtime difference between Ansys Static Structural and Transient Analyses Danito ANSYS 0 June 26, 2013 14:10
Static structural analysis using ANSYS Mechanical APDL sds10 ANSYS 1 June 23, 2012 00:25
Import transient cfx-results for static structural analysis in Ansys WB 13 Colt Seavers ANSYS 1 August 11, 2011 06:01
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
