static temprature distribution in turbine blade
Old   February 19, 2007, 12:33
Default static temprature distribution in turbine blade
sam
What should be the static temprature distribution on a typical turbine blade, if we assume adibatic conditions on the walls.
1. should it be same on suction and pressure side 2. should be more on pressure side or viceversa.
sam
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 01:04
