turbulence source terms
Old   February 3, 2007, 09:45
Default turbulence source terms
George
Hello, is it better in the source terms of the k-epsilon equations to add the terms using DMAX1 or DBS? For example: SU=SU+C1*CMU*GEN*VOL*DEN*DABS(TE)/VIS OR SU=SU+C1*CMU*GEN*VOL*DEN*DMAX1(0.0,TE)/VIS
In other words, is it better to ommit the source terms, when in the beginning of the simulation (large residuals) sometimes k gets negative values, or to take its absolute values?
Thank you in advance
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
