Coefficient of Drag for Air and Water
Old   January 29, 2014, 12:59
Default Coefficient of Drag for Air and Water
kilroy's Avatar
kilroy is on a distinguished road
Let's say I did a air wind tunnel test on a cylinder and get a drag coefficient for a certain Reynolds number.
If I did the same test only by replacing air with water and keep the Reynolds number constant, will I get the same drag coefficient?
Thank you very much for your time.
kilroy
kilroy is offline   Reply With Quote
Old   January 29, 2014, 13:42
truffaldino's Avatar
truffaldino is on a distinguished road
for incompressible flows the answer is yes
truffaldino is offline   Reply With Quote
Old   January 29, 2014, 13:50
kilroy's Avatar
truffaldino, thank you for your response.
I agree that the pressure effect will be the same. But how about the viscous effects. Water and Air have different viscosity.
Will not that make a difference (especially for lower Reynolds numbers)?
Old   January 29, 2014, 14:35
This is whole idea of the reynolds number to express all the coefficients in terms of one dimensionless parameter. The reynolds number is the only parameter entering the dimensionless NS equation, so do not worry about different components of drag: Pressure to viscous drag ratio also depend on Re only.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
error message cuteapathy CFX 14 March 20, 2012 06:45
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
