Helical tube in tube, heat exchanger
Old   February 4, 2014, 07:03
Default Helical tube in tube, heat exchanger
soby sunny
sobzsunny1 is on a distinguished road
I modelled a Helical tube in tube heat exchanger by sweeping, first i did the axis and then selected a plane parallel and opened sketcher and drew one circle dia 23mm and 12 mm that is the outer fluid, and then swept it and then 12mm and 10 mm the inner tube and swept it, and then 10mm pipe the inner fluid.
while the outerpipe is taken as wall .. So i get 3 pipes .. now
i need help in named selections, there is cold fluid in the outer and hot fluid in the inner, 2 inlets and 2 outlets,
i gave 2 inlets and 2 outlets and solid pipe, but wen i go to setup and click boundary conditions it automatically takes a lot of parts like interior part solid etc.
Can any1 help me to solve this??
sobzsunny1 is offline   Reply With Quote
[GAMBIT] double pipe heat exchanger with helical fin around inner tube mozafarie ANSYS Meshing & Geometry 5 November 7, 2012 05:02
heat exchanger drawing in Ansys Geometry flyEmirates ANSYS Meshing & Geometry 1 June 7, 2011 08:01
[GAMBIT] Modelling of Helical-rod inserted in the inner tube heat exchanger is required fahad02999 ANSYS Meshing & Geometry 9 August 11, 2010 08:14
Modelling of Helical-rod inserted in the inner tube heat exchanger is required fahad02999 Main CFD Forum 0 February 22, 2010 18:54
How to simulate 3D shell and Tube heat Exchanger san FLUENT 2 February 22, 2006 05:44
