Validation: a fundamental question
Old   March 1, 2007, 17:27
Default Validation: a fundamental question
Not a guru
hello, i am new cfd beginner and i did some simulation of flow around cylinder at various Reynolds in fluent and cfx to get started. I did mesh dependency study and solution is not varying.
when post-processing the global Cd = f(Re) I obtain for both code the well know curve. I have found an example on the web below:
http://imartinez.etsin.upm.es/bk3/c12/Forced%20and%20natural%20convection_archivos/image022.jpg
Now if I also calculate the same local Cd for each nodes or face around the cylinder as a function of local Re (Re(theta)) I obtain the following:
- with cfx every point of each node or edge are located on this same curve (and the integrated average is). - with fluen the points are not on the curve but the integrated average is.
which code is right, fluent or cfx?
should friction versus Re follow this curve both globally AND locally or only the global value.
Later, I plan do look at the Nusselt as well (global and local)
What do you find with the software you use?
thanks in advance.
Old   March 3, 2007, 12:08
Default Re: Validation: a fundamental question
hello
not many real fluid dynammics specialist on this forum
Old   March 4, 2007, 04:43
Jonas
I'm not sure if I understand your questions, but you will of course not get the same global Cd = f(Re) curve for flow past a cylinder as you will if you for one global Re plot the local Cd = f(Re) for each cell-face on the cylinder.
The global Cd = f(Re) is governed different types of phenomena. At low Re you have a creeping stokes flow where the drag is dependent on friction forces and laminar separation. As the global Re is increased you start getting shear layer instabilities an a von Karman vortex street. At even larger Re, when the boundary layers start to become turbulent and therby avoid separation, you will also see a drag-crisis as a dip on the Cd = f(Re) curve at around 5*10^5. You will of course not see this type of behaviour for the local Cd = f(Re) curve for each cell face on a cylinder at one global Re.
By the way. To siumlate this type of flow, with shear-layer-instabilities, turbulent transition and the drag crisis, is not at all trivial. It is in fact very difficult.
Old   March 4, 2007, 04:46
Jonas
Hello Not a guru, it is not very smart to answer your own question like this.
question about uds tanven FLUENT 2 July 5, 2015 11:22
Fundamental output format control of field values and time dbxmcf OpenFOAM 1 January 12, 2011 10:50
Validation of wind turbine simulations using experimental data of much lower Re Dorit Main CFD Forum 0 March 31, 2010 05:20
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
