Non-Reflecting BC for unsteady Euler flows
Old   September 28, 1999, 11:28
Default Non-Reflecting BC for unsteady Euler flows
Rob Law
Can anyone give me some good pointers for non-reflecting BC's for 3D unsteady euler flow, I'm currently using extrapolation in a Dual-Time finite volume solver with Roe's flux differencing scheme.
Old   October 4, 1999, 16:46
Default Re: Non-Reflecting BC for unsteady Euler flows
Patrick Godon
The boundary conditions have to be prescribed on the characteristics of the flow (or alternatively the characteristics equations of the flow have to be solved at the boundary). Let me give you some references, and if you have any specific question, just post it here.
Abarbanel et al. 1991, J. Fluid Mech. 225, 557
Givoli, 1991, J. Comput. Phys, 1 (review paper)
Engquist and Majda, 1977, Maths Comput 31, 629
see also all the references therein. Extrapolation does not always work, only for the outgoing characteristics of the flow. For the incomming characteristics of the flow, exact values have to be prescribed at the outer boundary (or also the fast incoming characteristics can be set to zero to avoid incoming noise and numerical oscillations).
I hope this helps.
Patrick
Q-criterion in 2D flows Josh Main CFD Forum 5 June 15, 2013 07:13
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 02:23
euler euler multiphase modelling mdsvjpk FLUENT 0 July 23, 2011 11:11
3D Euler Equations for Compressive Flows Daniel Ventura - Brazil Main CFD Forum 0 August 3, 2006 07:05
Euler equations? Jan Ramboer Main CFD Forum 2 August 19, 1999 01:58
