Fortran direct input help
Old   March 14, 2007, 21:18
Default Fortran direct input help
Joe
This is a fortran code problem but I figure out the many fortran programmers might be able to help.
Suppose I have a simple code like this:
program test
integer :: i
print *, "input i"
read *, i
print *, i
end program test
Running the code will prompt me to enter "i", which will be printed.
Is there a way whereby I can input directly?
ie ./a.out 10
and "10" will be printed.
I was told by my school's computer staff that this is only possible in C, not fortran.
Is that true? Thank you.
Old   March 15, 2007, 00:26
Default Re: Fortran direct input help
Ananda Himansu
program test
integer :: i
read *, i
print *, i
end program test
Compile the above file, then run with
./a.out < 10
Old   March 15, 2007, 00:30
Markus Lummer
Hi Joe,
look into the Fortran manual for functions/subroutines for the processing of command line arguments, e.g. function iargc() and subroutine getarg(...).
Regards, Markus
Old   March 15, 2007, 00:34
Default oops my bad
Ananda Himansu
on second thought, that will not work! Sorry, my mistake. you would need a file called "10" containing the input, in order for the code to work as I entered it. I guess the code the way you had it is the best that Fortran can do in general. There is no general mechanism in Fortran to parse command line arguments, though it is possible in Linux to enter
echo 10 | a.out
to achieve the effect you want
Old   March 15, 2007, 03:20
Joe
Thanks Ananada & Markus.
I've tried the subroutine getarg. I am able to get a character sting but I need the arguments to be in real nos.
How can I do that? Is there something like a character to real no. conversion subroutine? I've searched google but nothing meaningful appear.
Old   March 15, 2007, 03:31
Markus Lummer
Hi Joe,
in Fortran, you can read from a text string like from a file. In order to read the double precision variable number from the character string text, try e.g.
character text*(80) double precision number read(text,*) number
Regards, Markus
Old   March 15, 2007, 03:32
Joe
Guess I was not looking hard enough. ;-)
For Intel compilers, the subroutine to convert character to real is dnum.
Thanks
Old   March 15, 2007, 03:33
Markus Lummer
Sorry, forgot the new lines.
character text*(80)
read(text,*) number
Old   March 15, 2007, 08:37
Joe
Wow, I didn't know this is possible too. It's better than "dnum" cos any compiler can use it.
Thanks again
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 05:37
subroutine FORTRAN // CFX in Spain spain CFX 0 May 23, 2006 06:12
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 09:34
