Hello
![]() i am using RSM to calculate turbulent Couette Flow. My program works well with high Re numbers but diverged with low Re numbers. Anyone has such experences? how can the Re number influent the performance of the program? |
don't have experience of exactly this but sounds like possibly the actual physics become unsteady at low Re and so you need to use the explicit solver. Run an unsteady simulation and compare the velocity contours at different time steps. You might see a wake that is changing position with time!
Otherwise, if you want a steady solution try bringing in relaxation factors towards the end of the solution AFTER the solution starts to become unstable but only bring down the relaxation factors a little for THE UNSTABLE EQUATIONS because it will take much longer to converge. Please note- IF YOUR SOLUTION IS STILL CONVERGING AND ISN'T TOO UNSTABLE THEN IT MAY BE WORTH JUST LETTING IT CONVERGE ANYWAY. If this worries you then try it with and without the RF's. You may get the same result but in half the iterations by just leaving it! but depends whether the solution is still converging or not! hope this helps. |
Thank you very much!!
I will try again ![]() |
2D mesh low cell numbers - UNSTRUCTURED | PB4 | ANSYS Meshing & Geometry | 1 | April 1, 2011 08:42 |
low and high Reynlods numbers | amar | FLUENT | 1 | July 23, 2009 11:51 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Compressible code at low Mach numbers | Peter | Main CFD Forum | 7 | May 15, 2003 07:12 |
