April 27, 2007, 02:21 |
Euler equations: steady state solution
Hi!
I'm implementing a code for solving the 2D Euler equations for an inviscid compressible fluid. I'm testing my code with some typical test cases found in the literature such as the subsonic flow around a circle. The time marching is performed until the density residual in L2 norm is 10^{-10}. I obtain correct solutions in the large majority of the simulations but in some cases I found that the residual convergence stops at 10^{-8}. Anyboudy knows some possible reasons for this behavior. Thank you very much in advance! Rubén |
April 29, 2007, 08:12 |
Re: Euler equations: steady state solution
The scheme used in your code will influence the result! Some shemes only rearch that precision!
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
under relaxation factor and the steady state | jing113cn | FLUENT | 0 | November 2, 2009 12:13 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
steady state, laminar vof_model | Garima Chaudhary | FLUENT | 0 | May 24, 2007 03:11 |
Euler equations? | Jan Ramboer | Main CFD Forum | 2 | August 19, 1999 01:58 |
