May 9, 2007, 18:29 |
CFD used to obtain general formula
I have a question about general application of CFD. In case an analytical or "semi-analytical" formula is determined by other ways, CFD can be used to confirm it. I've heard this is often used. How about getting a formula from CFD simulations that would have varying input parameters. Is this applied too? Thank you, Marcin |
May 13, 2007, 02:06 |
Re: CFD used to obtain general formula
I don not understand you ! We use the analytical results to validate the CFD solution
May 14, 2007, 12:59 |
Yes, but how about situation, where you do not have an analytical result. You get CFD solutions and then make a formula for flow (might we call it empirical) Would it be appropriate approach, when analytical solution is not that easy to find.
May 14, 2007, 21:38 |
I think i is appropriate to do that, but the cfd solutions should be validate by experimental data.
May 15, 2007, 12:31 |
Thank you!
please help me for general description of CFD | Jiyeon | Main CFD Forum | 3 | April 7, 2009 16:20 |
CFD Code Choice and General Advice | Alex Pope | Main CFD Forum | 26 | April 25, 2007 11:54 |
General CFD Question | sam kashan | Main CFD Forum | 15 | June 18, 2002 09:21 |
General Intro Course on CFD? | J. Garroni | Main CFD Forum | 0 | September 15, 1999 09:15 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
