Boundary conditions for axial rotor
Like Tree4Likes
Old   May 5, 2014, 15:49
Default Boundary conditions for axial rotor
Seroga
Seroga is on a distinguished road
Hi, everybody!
I'm a newbie in CFD-simulations and faced a problem of imposing boundary conditions to a rotating axial rotor.
Where are two next questions:
1. What boundary conditions I have to impose on inflow and outflow boundaries? Inlet total pressure and static outlet? Or inlet mass flow and "I don't know what" outlet?
2. Must I correct the speed of rotor rotation depending on inlet mass flow? Or speed is constant and I just vary mass flow independently?
Thanks beforehand for your answers!
Seroga is offline   Reply With Quote
Old   May 5, 2014, 20:33
Armağan
mabelsfatalfable is on a distinguished road
First assumption seems to be fine I guess but btw you should also try to take the rpm into account if you change the inlet mass flow. (since the compressor can choke if you vary the mass flow inside too much)
mabelsfatalfable is offline   Reply With Quote
Old   May 6, 2014, 22:44
RacMat
rvl565 is on a distinguished road
Pressure Inlet( total pressure defined ) with a pressure outlet ( static pressure defined) works well for me.
The way you generate the PV curve ( constant RPM ) for the fan is by increasing the outlet static pressure. higher the outlet static pressure less is the massflow rate.
crevoise and Seroga like this.
rvl565 is offline   Reply With Quote
Old   May 8, 2014, 06:25
Seroga
Thanks Armağan and RacMat for your answers.
But what if I want to impose mass flow on he inlet boundary (some solvers allow to do so). What should I impose on the outlet boundary in this case? Static pressure or smth else?
Old   May 8, 2014, 11:33
RacMat
You can use a mass flow inlet with a pressure outlet to impose mass flow restrictions, i have also seen people use the "target mass flow rate" option in pressure outlet, I am not sure if that is correct.
You could just vary the outlet static pressure (pressure outlet + pressure inlet B.C.s) and see which outlet pressure gives you your correct mass flow rate.
Old   May 8, 2014, 13:51
RacMat
Are you using rotor 67/37 by any chance?
Old   May 8, 2014, 15:21
Seroga
Originally Posted by rvl565 View Post
I doubt about I've understood your question correctly. English is not my native language.
I wanted to carry out a flow simulation in Rotor 67 or 37. Now I've built a CAD model of Rotor 67 on my own and I'm going to simulate flow in it using OpenFOAM.
Old   May 8, 2014, 18:16
RacMat
I just wanted to know if you have the mesh for rotor 67.
Old   May 9, 2014, 14:41
Seroga
Actually I don't have the mesh yet. I'm working on it now.
Why don't you use *.tin mesh from https://grabcad.com/library/nasa-rotor-67-1 or this one: http://aero-comlab.stanford.edu/vdwe...ModTipGap.cgns
Old   May 10, 2014, 11:21
RacMat
Actually i tried using the stanford mesh... i modified it by removing the tip gap... but it isnt working for me ... heres the link to my post :
http://www.cfd-online.com/Forums/flu...on-fluent.html
I have included the cgns mesh file in a later post in the same thread....
I dont use ICEM so cant really use the first link...
Could you please let me know if you succeed?
Old   May 11, 2014, 05:34
Seroga
Sure, I will tell you if I succeed.
Tell me please about the mesh, you've used. Is it whole rotating? But as I can see it is larger than a rotating part of Rotor 67.
Old   May 11, 2014, 19:37
RacMat
I extended the inlet and outlet of the mesh by stanford.
It has 3 zones
inlet zone and outlet zone are stationary
rotor zone is rotating.
Have you started your simulations or are you building your mesh?
Old   May 15, 2014, 19:39
RacMat
hi,
were you able to make the mesh i shared with you work?
Old   May 16, 2014, 04:59
Seroga
Hi!
I can't use that mesh because I can't understand how to apply it to this problem. It's larger than rotating part of Rotor and I don't know how to define rotating and stating parts in it. Maybe this is because my little experience in this field.
I have already built my own geometry and built my own mesh. It is very coarse because I just want to find out would it work at all. But I faces a problem of cyclic boundary conditions in OpenFOAM and stuck a bit.
I will write to this post as soon as I will obtain some positive results.
Old   May 17, 2014, 10:45
vijaymali's Avatar
Vijay Mali
vijaymali is on a distinguished road
Send a message via Skype™ to vijaymali
Hi Seroga,
I hope you have received the answer to your original question about what boundary conditions you should you. I still want to give my opinion on that question.
The type of boundary conditions you should use, depends on the objective of the simulation (what data you want as a output) and what data is available with you.
In most of the turbo simulation problems that we do, we use mass flow rate at inlet and static pressure at outlet. We provide fix RPM to the rotor and extract what is the pressure developed at inlet. That way we can extract pressure rise, efficiency etc. for one point on the characteristic curve. For other points, we vary mass flow rate maintaining same RPM.
I have just gone through the later part of this discussion. I am curious to know what software you are using for meshing and what type (hexa or tetra mesh) of mesh you are generating ?
Thanks
Vijay
www.learncax.com
Chong070940103 likes this.
vijaymali is offline   Reply With Quote
Old   May 18, 2014, 13:56
RacMat
Hi!
hi,
I dont know much about OpenFOAM but in fluent i can set the RPM of the three zones (inlet, rotor and outlet) independently. Thus i set the rotor to have -16043RPM. I leave the other two zones as they are.
Old   May 18, 2014, 14:00
RacMat
Originally Posted by vijaymali View Post
Hi Seroga,
Thanks
Vijay
www.learncax.com
I use pointwise for meshing and generate a hex mesh in the whole domain.
As per your comment on boundary conditions, I have read at many places that for fan simulations people generally use pressure inlet and vary the outlet static pressure to generate a PV curve. I thought this method is correct? If not, what is the advantage of using a mass flow inlet over using a total pressure inlet?
Old   May 18, 2014, 15:00
Seroga
hi,
Sure, I can do so for my mesh. Because I define that zones during the mesh generation. But I don't see that they were defined in this mesh and do I don't know how to define that zones for existing mesh.
Old   May 18, 2014, 15:04
Seroga
Thanks, Vijaymali, for your answer. It was helpful.
Hi Seroga,
I use Salome to build geometry and mesh generation. I use structured hexameshes.
Old   May 18, 2014, 15:32
RacMat
I can generate meshes for OpenFOAM using pointwise. I generated the following mesh, let me know if this is working for you,
https://drive.google.com/folderview?...28&usp=sharing
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Helicopter Rotor in Hover - Pressure Farfield Boundary Conditions mjforsteruk FLUENT 3 January 8, 2015 02:47
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
