May 8, 2014, 12:22 |
Body Forces Computation
Rafael Pérez
Hi there,
I am using an in-house finite difference code which has the values located at the grid vertices and I need to calculate the pressure force acting on a wall boundary. I am using a structured mesh. Because the code uses generalized coordinates and grid metrics, I was thinking if I can perform the integration on the computational domain and then obtain the real force using the jacobian of the transformation. i.e. where and J is the Jacobian of the transformation between x,y,z (or x,y,S(x,y)) and xi,eta,zeta. Is that possible? Thank you very much |
generalised coordinates, grid metrics, lift calculation, pressure force |
[General] 3D Human Modelling with Body Surface Area and Volume Computation | Presly | ParaView | 0 | June 12, 2013 20:34 |
Body forces on hovering airfoil | sanmysterio | Main CFD Forum | 1 | July 13, 2010 03:14 |
Error with forces computation in 1.5 | aaurouss | OpenFOAM | 5 | July 21, 2009 05:53 |
strong body forces | Ankan | Main CFD Forum | 0 | August 2, 2005 02:13 |
Body Forces | Thomas P. Abraham | Main CFD Forum | 1 | April 21, 1999 21:24 |
