A plaque exposed to the air (boundary condition) |
May 29, 2019, 21:30 |
Hello
I have a very thin plate heated by an internal heat source, I want to cool this plate by the air what are the boundary conditions ??? Thank you for your attention |
May 30, 2019, 03:10 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
This is a conjugate heat transfer problem, you need to solve the solid-air interaction. At the interface you need to set the congruence of the two heat fluxes |
May 30, 2019, 10:04 |
I consider the air as a cube of length a, I propose at the entrance of this cube (Pressure inlet) and the outlet (Pressure outlet), Is this true ???
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 15:04 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
