Evoapration of droplet
Old   June 8, 2007, 05:49
Default Evoapration of droplet
wzslj
Hi! friends,I was studying on the mathematical simulation of the droplet drying.
The mathematical expression of the droplet's diameter is d(rd)/dt=-km*M1*(pvs-pv&infin/(R*ρl*Tav) (1)
drying conditions: r0=0.00075mm, T∞(environment temporature)=60℃ and RH=80% km=Sh*Dg/(2*rd) (2)
In equation(1): the molar mass of the water M1=0.0018kg/molar; R(gas constant) = 8.314; ρ1=1000kg/m3; Tav(temperature difference between the surface anfd the surroundings)=40℃ In equation(2): Dg(the diffusion coefficient of water vapor)=1.32e-5 Sh=2+2*(rd/r0)^0.5 (3)
Questions are: The vapor pressure of the air pv&infin;(T&infin;=60℃)=RH*ps&infin;(saturated vapor pressure),=15936pa,but the saturated vapor pressure of droplet surface (T=20℃)=2331pa<15936pa. The temperature of droplet rise until the saturated vapor pressure of droplet surface is greater than the gas vapor pressure. Then the droplet starts evaporating. But the droplet diameter by the simulating is smaller than the experiment results, why?
Many thanks!
Old   June 8, 2007, 15:05
Default Re: Evoapration of droplet
Feitoudaer
In the initial period during which the pressure difference is negative in your formulae, the droplet (may) undergo the coagulating process, i.e., the dropet diameter getting bigger, as shown by Eq. (1). Do you account for this process?
droplet impact on a dry surface.... VOF again rogerspass FLUENT 1 June 27, 2016 02:12
droplet falling - VOF bohis FLUENT 1 July 10, 2013 04:28
DieselFoam Droplet Temperature Issues - OF 1.6 viv05 OpenFOAM 0 February 27, 2010 11:20
Importance of droplet size Itchie CFX 2 December 13, 2007 02:01
DPM Modelling: Colloid droplet evaporation Meng Wai Woo FLUENT 1 August 1, 2007 00:27
