Axial compressor bleed modelling
Old   March 12, 2010, 05:14
Default Axial compressor bleed modelling
Kishore Kumar C
Kishore is on a distinguished road
Can anybody tell me how to modelling bleed massflow in a multistage axial flow compressor blade row using Ansys CFX.
The model is a mutli stage compressor with bleed in a rear stator blade row . There was no option to specify the bleed region using Turbogrid (pre processor) or model it in the CFX-pre.
I dont want to specify the entire shroud above the blade row as an outlet. I wanted to define a small area in the shroud as hole for bleed.
Thanks,
Kishore
Kishore is offline   Reply With Quote
Old   May 28, 2014, 20:00
Gamil
zizoc1 is on a distinguished road
Hi Kishore,
Did you find an answer for your question??
Actually I am trying to simulate the same problem that you mentioned here and I do not know how to do it.
It would be great if I can get some help,
Thanks,
ZIZO
zizoc1 is offline   Reply With Quote
axial compressor, bleed, cfx, multistage
Modelling Axial Flow Fans buzzybee Main CFD Forum 1 July 29, 2009 09:45
Surface streamlines on axial flow fans Jennifer CFX 2 February 17, 2009 14:50
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Examples of axial fan modelling Jenny FLUENT 1 November 30, 2006 12:25
Computational Modelling of Vortex Separators May Lim Main CFD Forum 6 November 13, 1998 12:36
