free aoustic solver
Old   June 29, 2007, 08:24
Default free aoustic solver
miko
hi all!
does anybody know a free acoustic solver, that solves the 3d wave equation and where i can download it?
regards miko
Old   June 29, 2007, 08:39
Default Re: free aoustic solver
lius
I also want to get it,but i cannot find a good one! i know some solver- FWH2d from NASA, and wopwop from NASA, but i could not use them outside the USA. it is a pity! so could someone tell me where i could get a DRP or a high order compact difference (HO C) code and a aeroacoustic solver?
Old   June 29, 2007, 17:23
Harish
When you talk of an aeroacoustic solver you need to be more specific.In aeroacoustics people use
1. Incompressible CFD + Lighthill/FW-H/Kirchoff 2. Solve directly using high-order methods (FDM,FVM)
The high-order solver market is relatively new.What applications are you working on ?
Old   June 29, 2007, 21:12
lius
thank you for your reply ,Harish. I have do many jobs about the LES+FW-H ,and get some results,but i find there is some disadvantages about this method. so now, I Use the direct noise computation(DNC). it mean using the high order methods. I used Ce/SE scheme from NASA,
compact difference scheme from LeLE, and so on. but only two-dimension .the three-dimension code is difficult for me ,so i want to get a free code!
Old   June 30, 2007, 14:26
Harish
The extension to 3-D would be straightforward assuming you have the grid already generated for you.You might want to look into the website of Dr.Lele.The dissertations of his students are available there.It might give you details of the implementation of the methods in 3D and issues involved.Hope this helps.
Best microfluidic free surface solver? Lars Main CFD Forum 8 January 17, 2012 04:48
Help for constructing an Unstructured Incompressible solver moomba Main CFD Forum 0 February 25, 2010 15:38
free " ordinary differential equations solver" ztdep Main CFD Forum 2 March 21, 2006 01:58
Convergence with coupled implicit solver Henrik Ström FLUENT 1 October 29, 2005 03:57
Error during Solver cfd guy CFX 4 May 8, 2001 06:04
